Dan Vance RacingCycleGear.comSportbikeTrackGear
ProCharger.comRRcycles.comJekillandHyde.euLeslie Kay'sJardineProducts.comMotorcycle.com Classifieds!
CycleGear.com
Old 07-04-2009, 08:27 PM   #1 (permalink)
Harleyrider1989 is on a distinguished road
oil leaking from front head on evo
then compression leakage........warped head ya think.What can I do
Harleyrider1989 is offline   Reply With Quote
Old 07-05-2009, 12:07 PM   #2 (permalink)
econnor is on a distinguished road
you have to pull the heads. they will probably need to be decked to get them flat. You should also look for what caused this to happen.
econnor is offline   Reply With Quote
Old 07-05-2009, 12:56 PM   #3 (permalink)
I just put the heads back on with teflon head gaskets.I had bad rocker boxes leaking profusely and I installed new oversize rings. Before that I had cometic head gaskets,never had a problem with them...was wondering if the head might be warped. I torqued them 7 lbs then 14lbs plus a quarter turn. The back cylinder is just fine.
Old 07-06-2009, 09:14 AM   #4 (permalink)
DILLIGAF
RattFXR is on a distinguished road
Did you really stop at 14lbs then a quarter? If you did, it will pop a gasket again. I think the factory torque stops at 30 something then a quarter turn. There are many different tq seq, but a quarter after 14 is only going to be 17-20 lbs.... not enough. If you have a bump in compression, put in SE cylinder studs and use your stock caps. They make a huge difference...
It's a machine, it's fixable. Unlike a woman.......
If it's "right", fix it......if it's "wrong", milk it as long as you can......
RattFXR is offline   Reply With Quote
Old 07-06-2009, 09:35 AM   #5 (permalink)
Ive got the factory book and it says 7 to start then to 14 and a quarter turn. If it should be more PLEASE LET ME KNOW.........I just wanna ride...........this is my first evo..Ive always had ironheads and shovelheads since 1977.
Old 07-06-2009, 11:12 AM   #6 (permalink)
I've been called abrasive
DBChoppers's Avatar
DBChoppers is on a distinguished road
7lbs. then 14lbs. then turn 90*
SCREAMIN' EAGLE
Tastes just like chicken
www.Diamondbarchoppers.com
DBChoppers is offline   Reply With Quote
Old 07-06-2009, 03:08 PM   #7 (permalink)
ty......you rock
