American Side Road CycleSportbikeTrackGearJardineProducts.comBikeBanditProCharger.comBub EnterprisesDiamond Bar Choppers
Old 07-01-2009, 05:46 PM   #1 (permalink)
redharley1200 is on a distinguished road
top end noise
Just did a 883 to 1200 upgrade.... problem is I get it up to 3000 rpm and get a lot of noise in the FRONT cylinder, it sounds like the top end. If I back it down it sounds fine...idles great... I've checked to make sure the push rods are correct ( longer one is exhaust )... any suggestions ???
redharley1200 is offline   Reply With Quote
Old 07-03-2009, 03:51 PM   #2 (permalink)
OUCH! That hurt
wfolarry's Avatar
wfolarry is on a distinguished road
Did you change cams with the upgrade?
35 years of ridin' & wrenchin'
wfolarry is offline   Reply With Quote
Old 07-03-2009, 04:05 PM   #3 (permalink)
was this a boxed HD kit, or did someone convert for you?
Old 07-03-2009, 04:36 PM   #4 (permalink)
TheNowhereman's Avatar
Check your lifter/valves for being set up too loose.
You could have a lifters that are not getting oil.
Nowhereman who else?
Old 07-03-2009, 06:31 PM   #5 (permalink)
I used the Stock cam
Old 07-03-2009, 06:31 PM   #6 (permalink)
It was a boxed kit
Old 07-03-2009, 06:32 PM   #7 (permalink)
You think I should use adjustable push rods ??
Old 07-03-2009, 06:42 PM   #8 (permalink)
my first check would be pinging. and i would eliminate that immediately.
Old 07-03-2009, 09:38 PM   #9 (permalink)
Pinging ?? what do you mean ??
Old 07-03-2009, 11:24 PM   #10 (permalink)
DILLIGAF
RattFXR is on a distinguished road
Clay is basically asking if the carb was jetted for the conversion. If you are running the already lean jets for and 883 in a 1200, then your air/fuel mix is way lean. THATS BAD. You will burn a hole in a piston quick. If all that was changed was the bore, then technically speaken, you shouldn't have any problems. If you have "top end" noise on a stock converted motor, then you should check out your oil. If your running a low level, it can cause the problem. If it's normal then try a higher viscosity such as a straight 50. This will stay thicker and help keep things snug. There are mean things that can cause this problem, but the air/fuel and oil are the first check. If you set the motor up, and the pistons are tight, then you might have an overheating problem which is causing the oil to break down and not absorb the heat, which will eventually melt a piston.....see the trend? Fuel (air/fuel ratio) cools the combustion chamber, and the oil cools and cushions motor. A converted 883 is basically the same thing as a 1200. If it ran right before the conversion, then it will run right again.
It's a machine, it's fixable. Unlike a woman.......
If it's "right", fix it......if it's "wrong", milk it as long as you can......
RattFXR is offline   Reply With Quote
Old 07-04-2009, 08:23 AM   #11 (permalink)
two things came to mind.
1. going to 1200 and retaining the 883 heads puts the compression through the roof, installing 1200 kit (with 1200 heads) on top of stock cams may do the same, and with no overlap it would run hotter. both situations cause ping.
2. as mentioned, lack of tuning. timing AND fuel need to be addressed, not doing so-------ping.
Old 07-04-2009, 10:25 AM   #12 (permalink)
I guess I should have been a little more specific about the the build....sorry, like I said I'm a newbie....here's what I got .....883 with 1200 conversion kit (cylinders, pistons, rings) S&S (e) Carb 0with thunderjet set-up, H-4 crane ignition. I started with Mobil One 20w-50w took that out and went straight 50w with some Lucas additive.The sound I hear is more of a knock, than a ping....almost like a rod knocking but coming from the top end. Like I said it doesn't do it until I take it over 3000 rpm.
Old 07-04-2009, 04:04 PM   #13 (permalink)
OUCH! That hurt
wfolarry's Avatar
I haven't done an 883-1200 conversion in a long time so I'm out on a limb here but I'll throw out a few things I remember.
They used to give you a template for opening up the combustion chambers to reduce the compression. Do they still do this? Or do the pistons have a dish top? Just trying to get a little more specific on what you did & maybe find the problem.
Old 07-04-2009, 06:37 PM   #14 (permalink)
Iron Will
Hillside's Avatar
Larry,
Wiesco(if that was used) offers a dished unit.
Scott
Old 07-05-2009, 08:50 AM   #15 (permalink)
Don't remember off hand......I'm gonna pull it apart and find out. If something don't jump out at me I'm gonna turn it back into an 833 for the summer and re-do it over the winter.
