JekillandHyde.euJardineProducts.comMBO EnterprisesDiamond Bar ChoppersAmerican Side Road CycleSportbikeTrackGearMotorcycle-CommunicationCustom DynamicsFuel MotoProCharger.comBub Enterprises
Custom Dynamics
Old 06-27-2009, 06:47 PM   #1 (permalink)
dochawken is on a distinguished road
EVO rebuild
I have 122k on my 98 Evo and since I just love the way it has performed I am going to rebuild it...so far I have new jugs, pistons , rings, oil pump upgrade...the heads are SE 10.5 which I will have worked. The bottom end is pretty simple or not? Why I'm buying the parts I would appreciate any and all suggestions. Doc
dochawken is offline   Reply With Quote
Old 06-27-2009, 08:00 PM   #2 (permalink)
Iron Will
Hillside's Avatar
Cranks are easy as long as you are tooled up to do the job. Trueing stand, torque wrench, torque mutiplier, balance tooling, flywheel fixtures, precision surface plate(HAS to be level) and either a drill press or milling machine.
Scott
Old 06-28-2009, 02:05 AM   #3 (permalink)
Sarge7's Avatar
Sarge7 is on a distinguished road
cheaper to take the crank/rods and bearings into your local indy or HD shop and let them do it for you. Saves on the headaches later on if something ain't right.
Sarge7 is offline   Reply With Quote
Old 06-28-2009, 09:33 AM   #4 (permalink)
Former Marine
tx_shooter's Avatar
tx_shooter is on a distinguished road
Scott
Lol... I'm thinking anyone who has all of that wouldn't be asking how hard they are to do. But that might be just me. As for doing the bottom end work - its easier/ safer sending it to a shop setup with the equipment than hope it was done right at home.
1997 Fat Boy
Evo Motor w/
9.5:1 Keith Black Pistons
Andrews EV27 cam
CV Carb
Crane Fireball HI-4E Ignition
tx_shooter is offline   Reply With Quote
Old 06-28-2009, 01:13 PM   #5 (permalink)
02 RK,S&S 124" Evo
dog155's Avatar
dog155 is on a distinguished road
I agree,I have been doing my own motors for years and just can't justify setting up to do cranks.Everything else is quite easy,don't assume anything ask the right questions you will be glad you did.Good Luck
06 RK,155" R&R TwinCam
02 RK,124" S&S Evo
dog155 is offline   Reply With Quote
