60 wt in a TC95
Guys, since I built my '02 FXDX with a ZIppers 95 Muscle kit a few years ago, it's always run strong and been trouble-free. However, it does have an annoying valve noise between about 3k and 4k rpm. The Baisely spring was installed and helped a little.
I decided to experiment with a heavier oil, and just put in straight 60 wt dino. I had been using Mobil1 20-50. I would have gone with a mult-vis 60, but I couldn't find any locally.
It's too soon to know for sure, since I just ran it in the garage, but the bike seems much quieter. It sounds better than it ever has, throughout the rpm range. No problems starting either, in 50 degree weather. I do have compression releases.
Should I have any concerns? Thanks a lot,
John
