103" Oil Capacity? : V-Twin Forum: Harley Davidson Forums
Old 02-28-2006, 12:35 PM   #1 (permalink)
This space is blank
DCRANER's Avatar
DCRANER wants to know Dino or Syn?
103" Oil Capacity?
Dealer currently working on a SE 103 for my FXDWGI along with adding the Premium Oil Cooler #26081-05.
Question; Is the 103 engine oil capacity different than my base TC88, and how much additional oil is required when adding the oil cooler?
Also, the Preemium Oil Cooler indicates it has a thermostat, does that mean the seperate Thermostat Controller would not be needed?
2012 Heritage Softail Classic, profile laced wheels, security, ABS, two tone color - Ember Red Sunglo / Merlot.
DCRANER is offline   Reply With Quote Quick reply to this message
Old 02-28-2006, 05:02 PM   #2 (permalink)
road_king's Avatar
road_king wants to know Dino or Syn?
According to numerous specs listed on the web, the SE 103 oil capacity is 4 qts. Same as Twin Cam 88 motor.
The premium oil cooler comes with an integrated thermostat, so there is no need to add a second one.
It will require extra oil. How much? Not sure, but just fill it as usual until the reading on the dipstick is correct.
road_king is offline   Reply With Quote Quick reply to this message
Old 02-28-2006, 09:10 PM   #3 (permalink)
06HawgSG wants to know Dino or Syn?
Neither you oil pan or bottom end on your motor changes in size or capacity when upgrading to a 103" build. So, the oil capacity is the same as stock.
There should be an owner's manual or paperwork that came with your oil cooler which would tell you the capacity of that item to add to your base oil total when refilling. Also, always go about 1/2 quart below what the book tells you. That will keep you from having any problems with blow-by into your air cleaner.
Good luck,
06HawgSG is offline   Reply With Quote Quick reply to this message
Old 03-07-2006, 12:33 AM   #4 (permalink)
B-Rad, BFMC 104
RideMyWideGlide's Avatar
RideMyWideGlide wants to know Dino or Syn?
My 05' book says 3qts. I put 3 qts in when I change the oil and it's full.
But the dealer seems to always charge me for 6qts when they do it. I guess they know how to cram more oil in there than is possible for us mortals.
Go figure.
Brad
B-Rad BFMC 104
2005 WideGlide
GMR Performance 98" Kit
37G's, Andrews drive
Some head work
48mm Funnel'd TB
Vrod Injectors
Amsoil
1 3/4" Drag pipes
View my Gallery
Hang on to your wallet, obama's economic stimulus plan is on the way....
RideMyWideGlide is offline   Reply With Quote Quick reply to this message
