Mobile 1 in the primary : V-Twin Forum: Harley Davidson Forums
Old 08-30-2013, 03:35 PM   #1 (permalink)
Kent's Avatar
Kent wants to know Dino or Syn?
Anyone using V-Twin 20W50 Mobile 1 in the Primary? Observations Please.
Kent is offline   Reply With Quote Quick reply to this message
Old 08-30-2013, 03:47 PM   #2 (permalink)
webco2 wants to know Dino or Syn?
I have in the past without any problems. I use ATF now .
webco2 is offline   Reply With Quote Quick reply to this message
Old 08-30-2013, 05:21 PM   #3 (permalink)
Olivepearl wants to know Dino or Syn?
I have used it and it was ok I just don't like using Synthetic Oil in the primary. I use HD Formula +
Olivepearl is offline   Reply With Quote Quick reply to this message
Old 08-30-2013, 05:29 PM   #4 (permalink)
robystyle's Avatar
robystyle wants to know Dino or Syn?
I used it and was fine till I went to 107 and then it slipped so I put a Barnett pressure plate in and formula plus in and hasn't sliped since don't know if it was the synthetic causing the sliping or not
robystyle is offline   Reply With Quote Quick reply to this message
Old 08-30-2013, 05:46 PM   #5 (permalink)
not sober all the time
Uncle Salty is reading this now saying WTF is this? Uncle Salty is reading this now saying WTF is this?
I use Mobil 1 in the crankcase but it baffles me to think one would want to use it in the primary.
Uncle Salty is offline   Reply With Quote Quick reply to this message
Old 08-30-2013, 06:44 PM   #6 (permalink)
Dan89FLSTC wants to know Dino or Syn?
No way to observe it while it is in there.
Dan89FLSTC is offline   Reply With Quote Quick reply to this message
Old 11-12-2013, 03:38 PM   #7 (permalink)
John Adams's Avatar
John Adams wants to know Dino or Syn?
Why? Based on what?
South Park does Harley:
https://www.youtube.com/watch?v=xGyKBFCd_u4
John Adams is offline   Reply With Quote Quick reply to this message
Old 11-12-2013, 04:54 PM   #8 (permalink)
hardheaded wants to know Dino or Syn?
been using it in my two bikes for years, works great. why not use the best you can buy?
hardheaded is offline   Reply With Quote Quick reply to this message
Old 11-12-2013, 05:27 PM   #9 (permalink)
Nitram_b4's Avatar
I have used it in the past, and I liked it. seemed to smooth out shifting.
But I had it in the tranny and primary at the time
2000 FXSTS
97"
KB Pistons
Ported heads
SE 203 Cams
Fueling Camplate and Pump
Fueling lifters
S&S Quickie Push rods
Red Shift Hyd Tensioners
HRS 42 Mikuni Carb
DTT Ignition
Nitram_b4 is offline   Reply With Quote Quick reply to this message
Old 11-12-2013, 05:35 PM   #10 (permalink)
Originally Posted by John Adams View Post
Why? Based on what?
I used Syn 3 and Mobile 1 syn until my clutch started slipping. Then I went to Formula + and now i use Dexron III it shifts, releases, grabs better.
Old 11-12-2013, 05:41 PM   #11 (permalink)
gusotto's Avatar
gusotto wants to know Dino or Syn?
Myself, I use primary (Spectro) oil for the primary.
I figure it's made for that purpose and I have to put "something" in there, why not use oil designed for that reason?
Many miles between changes so I do get my moneys worth.
I also use "real" tranny oil. (Says so on the bottle.) Same with engine oil.
I have thousands "invested" in my bike. Why not use oil designed for their specific purpose?
Same feelings toward oil filters.
Bike repair isn't cheap so why "cheap out?"
gusotto is offline   Reply With Quote Quick reply to this message
Old 11-22-2013, 04:30 PM   #12 (permalink)
John Adams's Avatar
That had nothing to do with the fact that it was syn. Thousands of others use syn in the primary with no problems at all. Nothing wrong with Formula + though.
Old 11-22-2013, 06:46 PM   #13 (permalink)
Sure it did It slipped! And adjusted correctly... And the Thousands that use it don't run the $hit out of their bike like i do!
Old 11-22-2013, 08:43 PM   #14 (permalink)
wichitagreg's Avatar
wichitagreg wants to know Dino or Syn?
Formula + is designed for the Primary. Works well.
I mad a mistake and put a fancy synthetic oil in my primary, cost me an hour labor and a primary gasket at the dealer to find out not to do that.
Formula + in the primary for me.
wichitagreg is offline   Reply With Quote Quick reply to this message
Old 11-22-2013, 09:14 PM   #15 (permalink)
1rusty1's Avatar
1rusty1 wants to know Dino or Syn?
I use it in all three on both my 98 Ultra and my 2013 Limited. No problems that I have experienced.
1rusty1 is offline   Reply With Quote Quick reply to this message
