11-06-2012, 10:59 AM
What The BEST Tranny Oil Out There
Hi Guys
In your opinion: What The BEST Transmission Oil Out There For A Five Speed Tranny ?
Also: When do you guys CHANGE your transmission oil ?
Thanks Guys
Schooner
GOD BLESS ALL
11-06-2012, 12:07 PM
Redline heavy shockproof. Every season.
Sent from my GT-I9100M using Motorcycle.com Free App
11-06-2012, 04:31 PM
The transmission will last just about forever no matter what gear lube you use.
I use 90w, whatever brand is on the auto parts store shelf...
11-06-2012, 05:09 PM
The search option can be our friend................There are enough threads on here related to oil to give you a headache.
Patriot Guard ID #181788
US Navy Veteran
11-06-2012, 05:16 PM
Hummmm ! REDLINE
Hey My Good Man
To be honest with you I NEVER heard of REDLINE Tranny Oil.
Why do you like it so much and how long have you been using it
Thanks Guys
Schooner
GOD BLESS ALL
11-06-2012, 05:24 PM
Not sure where I put it
I started using Redline to figure out where a leak was coming from and have used it since.
11-06-2012, 05:26 PM
Viel Vergnügen
I used straight weight 50 in my old shovelhead and it ran 167,000 miles. The motor gave up but the trans was going strong.
What do you use in your car? That trans is way more $$$.
11-06-2012, 05:36 PM
Redline shockproof heavy. Have tried Mobil-1 75/90, 75/140, Belray 85/140, and Amsoil severe gear 75/140. Redline is the quietist and smoothest I've tried.
 2008 FLSTF
117", cvo 110 heads by Wolfgang, TW68's, HPI 58/62, boarzilla. 138hp/132tq SAE
2012 FLTRX (new baby)
S&S powertune duals, Rinehart 4" slip ons, Kuryakin Mach II AC, 78hp/99tq SAE
11-06-2012, 05:52 PM
T h a n k y o u a l l g u y s
Hey monkeybutt
Thank to all you guys ~ REDLINE is the tranny oil I will buy for my 1985FLHTC
Just had it ALL RE-DONE:
Two Tone Paint Job.
Wide White Walls.
New S&S Carb.
New Battery.
New Coil.
New Ignition Module.
Etc,etc.
BUT I'M A HAPPY MAN
Thanks Guys
Schooner
GOD BLESS ALL
11-08-2012, 07:11 AM
Redline is nearly twice as thick in viscosity as most other gearlubes used in Harleys and that fact alone may make things a little quieter, but it will not out live any other gearlube on the market in a Harley. No matter what fluid one uses the tranny will still hold together well and will usually out live the rest of the components on the bike. A harley tranny will live a long life using a motor oil or a gearlube no matter what the level of noise the rider is hearing unless there is a manufactures defect in the tranny or some one fails to use the clutch correctly when shifting. The tranny was designed for fluids using anti-wear additives like in a motor oil and does not require gearlubes using extreme pressure additives, but most like the piece of mind that a gearlube provides.
george
 Buying Amsoil from us, your forum sponsor, helps to support this site. Orders are shipped ASAP from our nearest US or Canadian warehouse. George@OilHelp.com,
Forum members call or e-mail me for your special discount pricing.
11-08-2012, 01:26 PM
redline,also use redline 20-60syn.oil gooood siht!
11-13-2012, 08:51 AM
redline in the 6 speed spectro in the 5 speed for now but will next change to redline
11-13-2012, 09:06 AM
i really noticed a difference on my 05 with belray gearsaver. shifted 10x smoother and easier going into neutral
Sent from my SGH-I727R using Motorcycle.com Free App
2005 Ultra classic
-1550 BB kit/Woods WT6/SE adjustable push rods/PCIII
-Mountain MAchining Heads/1.9 intake/1.6 exhaust
-4.6CC CP Pistons/zero deck hieght f/r
-10.2:1
-94hp/103Ft/lbs torque
-V&H TD head pipes/Rienhart Slips
-Baileys Spring/WB easy clutch
-Mustang seat/WW and Spokes
-34 tooth Andrews pully
-Racetech front springs and emulators
-Dyno'd by Bruce @ Dynotunes
2012 883 Superlow
-Windshield and bags
-Mustang solo seat
11-13-2012, 12:08 PM
It's funny how everyone always notices a difference when they switch to XYZ oil. Truth be told all they did was drain some old worn out oil and replaced it with new oil. Pick a gear oil to your liking and change it every 20k and the trans will more than likely outlive the rest of the bike.
When I hit 5k on my bike and went to change the engine oil I noticed a bottle of RedLine trans oil at my indy shop. I though what the heck, lets see what all the hoopla is about. I drained the HD Syn3 that was in my tranny for the past 4k miles and put in the RedLine. I honestly couldn't tell any difference. It didn't eliminate the clunk when shifting. It didn't make it shift smoother. It didn't give me better fuel economy. All it did was make my wallet $13 lighter.
11-13-2012, 12:10 PM
What are ya trying to get the most different responses?
06 FLHTCUI Ultra Classic
| Sponsored Links |
