What The BEST Tranny Oil Out There - Page 2 : V-Twin Forum: Harley Davidson Forums
Old 11-13-2012, 11:37 PM   #16 (permalink)
ucbruce's Avatar
ucbruce wants to know Dino or Syn?
Originally Posted by mayo73 View Post
Redline heavy shockproof. Every season.
Sent from my GT-I9100M using Motorcycle.com Free App
Absolutely! Redline with "Shockproof" is the best. Been using it for years and use Redline in all three holes and change every 5000. You can do engine every 5K and tranny & primary every 10K if you want, but only if you use top shelf stuff like Redline. Last time I changed my fluids I think we had 5700 miles and the gear oil was as pink and thick as the day we put it in.
2013 FLHTK
SE 103 Stage IV Race Kit
SE Heavy Breather
V&H Pro Pipe Chrome
105 HP 106 Torque
ucbruce is offline   Reply With Quote Quick reply to this message
Old 11-14-2012, 01:15 AM   #17 (permalink)
emwolb wants to know Dino or Syn?
i also use the redline shock proof heavy, "pepto bismol" and it seems to quiet things down a bit. also by using b&m trick shift automatic trans fluid in the primary, that seems to help also. not as smooth as the metric bikes, but i loose quite a bit of the clunk when going into gear and the shifts seem smoother. O' reilleys auto parts now sells trick shift.
emwolb is offline   Reply With Quote Quick reply to this message
Old 11-14-2012, 01:06 PM   #18 (permalink)
hd4evr2008 wants to know Dino or Syn?
Been using this for awhile, switched from Redline. I like it much better:
Heavy Duty Platinum 6-speed Transmission Oil
hd4evr2008 is offline   Reply With Quote Quick reply to this message
Old 11-14-2012, 01:29 PM   #19 (permalink)
dbrow6272's Avatar
dbrow6272 wants to know Dino or Syn?
I use Bel Ray 85-120 in my tranny's. Remember there are needle bearings in the tranny and you want them to roll not slide.
Ride em hard and put em away wet!
dbrow6272 is offline   Reply With Quote Quick reply to this message
Old 11-21-2012, 06:49 PM   #20 (permalink)
Dave in Texas's Avatar
Dave in Texas wants to know Dino or Syn?
I also use Red Line V-Twin transmission oil with Shock Proof. Kinda looks like/reminds me of Pepto-Bismol....different taste tho. Did smooth-out shifts!
Dave
Veteran/Retired IBEW Lu520
2003 FXDL Stg 1 AC, SE slipons
CVP Tuner carb kit
Andrews Hyd kit w/21n cams
Ohins shocks, Intiminators in forks.
Mustang Vintage Solo & Pass seat
15" WindVest
J&S Dyna lift
Dave in Texas is offline   Reply With Quote Quick reply to this message
Old 11-21-2012, 06:50 PM   #21 (permalink)
hacksawsgarage wants to know Dino or Syn?
i currently have red line in both my shovelhead and dyna trannys.
i wouldnt use motor oil because the shear properties are different.
hacksawsgarage is offline   Reply With Quote Quick reply to this message
Old 11-21-2012, 06:54 PM   #22 (permalink)
chilsam's Avatar
chilsam wants to know Dino or Syn?
Stp
STP.......I've run that in my 82 FXR almost the ENTIRE time I've owned it since I bought it new 30 yr's ago.Tranny's NEVER been apart
chilsam is offline   Reply With Quote Quick reply to this message
Old 11-21-2012, 06:57 PM   #23 (permalink)
her20it12age wants to know Dino or Syn?
Red Line Shock Proof
her20it12age is offline   Reply With Quote Quick reply to this message
Old 11-21-2012, 10:36 PM   #24 (permalink)
olddad64 wants to know Dino or Syn?
Thumbs up Gear Oil
Redline Shock Proof for me too !! Great oil !!
olddad64 is offline   Reply With Quote Quick reply to this message
Old 11-21-2012, 10:57 PM   #25 (permalink)
FLHPI-02 wants to know Dino or Syn?
Its all ok. A while back I researched the wear factors on all the popular brands. It seems that Amzoil has the lowest wear factor of all. I run it in all three holes and that seems to work just nicely, weather I am cruiseing or running fast. No leaks no problems,and yes I have had some indys tell me they got something better,but if its running good why f**k with it.My scooter never goes into a Harley garage, for the same reason.adios T. J.
FLHPI-02 is offline   Reply With Quote Quick reply to this message
Old 11-22-2012, 01:11 PM   #26 (permalink)
3dusmc's Avatar
3dusmc wants to know Dino or Syn?
Everybody has their preferences, but just to throw in my 2 cents worth, I use all AMZOIL products in my bike!
3dusmc is offline   Reply With Quote Quick reply to this message
Old 11-22-2012, 01:41 PM   #27 (permalink)
Tequila SG's Avatar
Tequila SG wants to know Dino or Syn?
I don't know about " best" , they all make that claim but, I've had great results with Belray gear saver in the past, and now I'm using Amsoil severe gear on my 12 SG, is quieter and smoother shifting, I'm sure most would agree anything is better than the crap that's in it from factory . JMO
Sent from my iPhone using Motorcycle.com Free App
My dream is of a place and a time where America will once again be seen as the last best hope of earth.
Abraham Lincoln
Tequila SG is offline   Reply With Quote Quick reply to this message
Old 11-25-2012, 09:25 AM   #28 (permalink)
RG50 wants to know Dino or Syn?
The bearing skate thing,huh?
So dont use synthetic oil?
2011 Electra Glide Limited
RG50 is offline   Reply With Quote Quick reply to this message
Old 11-25-2012, 10:04 AM   #29 (permalink)
Average Dude
YankeeBob's Avatar
YankeeBob is reading this now saying WTF is this?
Originally Posted by tmd11111 View Post
I honestly couldn't tell any difference. It didn't eliminate the clunk when shifting. It didn't make it shift smoother. It didn't give me better fuel economy. All it did was make my wallet $13 lighter.
The clunk when going into gear has nothing to do with the transmission lube, and everything to do with the primary lube.
Deut. 23:12-13
YankeeBob is offline   Reply With Quote Quick reply to this message
Old 11-25-2012, 02:50 PM   #30 (permalink)
georgedouglas's Avatar
georgedouglas wants to know Dino or Syn?
What I have found through personal experience was to get the best shifting, the clutch and primary chain tension had to be adjusted correctly and using ATF gave me the best shift in my bikes. The fluid in the tranny has very little to do with the shifting characteristics unless it is masking something out of adjustment and then it is just a bandage.
george
Buying Amsoil from us, your forum sponsor, helps to support this site. Orders are shipped ASAP from our nearest US or Canadian warehouse.
George@OilHelp.com or 1-800-887-6698 or http://oilhelp.com/motorcycles
