What's with the "O" Rings on the drain plugs? : V-Twin Forum: Harley Davidson Forums
Old 03-11-2010, 09:11 AM   #1 (permalink)
est.1954's Avatar
est.1954 wants to know Dino or Syn?
I just changed my oil ( s )...( for the first time ) on my new ( to me ) 2008 Super Glide Custom.
What's with the rinky -Dink ...round " O " rings on the drain plugs....you tighten them and they squeeze out the sides.( they should at least be flat!!!!)
Is that what Harley does???? or did the previous own do something stupid like that?
I went to Nappa and got special drain plug washers 12 MM ( with rubber one side) cost $5 for 10.
est.1954 is offline   Reply With Quote Quick reply to this message
Old 03-11-2010, 09:23 AM   #2 (permalink)
Dave63's Avatar
Dave63 wants to know Dino or Syn?
This is why HD recommends that you change then with each oil change. They get ratty and torn after a while.
Of course, then HD makes $3.50 off the primary o-ring and $4.00 off each trans and oil drain plug.
Not sure why they don't use a better lasting or better, PERIOD, method of sealing the plugs.
I also see that overtightening the plug (it's a drain plug, not a lug nut) aids in the premature failure of these o-rings as well.
Dave
Dave63 is offline   Reply With Quote Quick reply to this message
Old 03-11-2010, 02:58 PM   #3 (permalink)
est.1954's Avatar
Thanks Dave
You are right...there are much better designs.
My v Star...had a plastic washer on the plug and I never had to change it ever.... in the 6 years I had it.
Good thing I didn't go to the HD dealer to replace the Rinky- Dink " O " Ring ...$3.50 - 4.00 ...that's a crime...... but I guess everyone has to make a buck.
That's why it pays to think...for yourself.
Brent
Old 03-11-2010, 03:02 PM   #4 (permalink)
Pop's Cycle wants to know Dino or Syn?
Thanks Dave
Brent
You may notta did it, but I think your supposed to. My car has a crush metal gasket that gets changed everytime. I've changed the gasket on my bike once - just cause I had the o-rings and felt like it. Certainly didn't look like it needed it.
Pop's Cycle is offline   Reply With Quote Quick reply to this message
Old 03-11-2010, 03:38 PM   #5 (permalink)
JRS
JRS wants to know Dino or Syn?
I agree with the OP.
Recently I checked the torque of my oil drain plug and found it to be low, because the o-ring had flattened out. I thought that was kinda scary.
JRS is offline   Reply With Quote Quick reply to this message
Old 03-11-2010, 07:55 PM   #6 (permalink)
257bob wants to know Dino or Syn?
I use 5 cent o-rings from the hardware store (-011, I think). If you use the right size o-ring it won't cause any problems for at least 3 oil changes. If you look carefully at the pan, you will see a groove where the o-ring is supposed to sit. An o-ring that is too big in diameter or cross section will cause problems.
The Cranky Yankee
257bob is offline   Reply With Quote Quick reply to this message
Old 03-11-2010, 08:04 PM   #7 (permalink)
In The Wind wants to know Dino or Syn?
$2.56 for a pack of 100 here.
http://www.mcmaster.com/#9452k57/=66en2b
In The Wind is offline   Reply With Quote Quick reply to this message
Old 03-11-2010, 08:52 PM   #8 (permalink)
crasha51pan's Avatar
crasha51pan wants to know Dino or Syn?
I just called the "local" HD Dealer (80 miles from my house) and had him send me a service kit that contained 3 o-rings (oil, trans, primary), and the gasket for the derby cover for 4 bucks and change.
I didn't think that was bad at all..
crasha51pan is offline   Reply With Quote Quick reply to this message
Old 03-28-2010, 10:54 AM   #9 (permalink)
rbabos wants to know Dino or Syn?
Those fkg mickey mouse plugs are not designed correctly. A thin flat washer needs to isolate the sharp edges of the hex part so it don't snag the ring and tear it out. At the very minimum the sharp edges on the hex flats need to be filed with a slight chamfer. As is, 50% of the time they snag the ring and it gets sheared off, no matter how much grease you apply or how carefull you are. Having worked in a hydraulic cylinder shop, I've cussed these things from the first time I did fluid changes. Time to make it right.
Ron
[SIGPIC][/SIGPIC
120 CI. Rivera Pro Clutch, HPI 55mm . 5.3 HPI Injectors. EVO 49 Tooth Clutch Sprocket. Head Designs By Dewey (Don) Supertrap 2-1
rbabos is offline   Reply With Quote Quick reply to this message
Old 03-28-2010, 01:06 PM   #10 (permalink)
berserker's Avatar
berserker is still riding a stock bike berserker is still riding a stock bike berserker is still riding a stock bike
I got to laugh guy with his 08.......
I've never had a leak on the oil plug. My 01 oil pan started eating them up around 30 or 40k. Can't figure out why. But no leaks, just replace on the next change.
I would think long and hard before I change the design on the oil plug. Your taking your engines life in your own hands. I had a Jword oil plug come loose once,, my fault, engine blew before I caught it.
berserker is offline   Reply With Quote Quick reply to this message
Old 03-28-2010, 02:08 PM   #11 (permalink)
MCE
MCE wants to know Dino or Syn?
I change them out every other oil change when I get the gasket kit. 3 o rings for drain plugs and primary cover gasket. I guess I should just order a few of them when i get some oil filters online and just have them ready to go.
MCE is offline   Reply With Quote Quick reply to this message
Old 03-28-2010, 02:17 PM   #12 (permalink)
berserker's Avatar
I inspect the orings, if they look ok I reuse them. I don't change out the primary, derby or inspection cover, I just keep reusing them.
Old 03-28-2010, 05:09 PM   #13 (permalink)
rscalzo's Avatar
rscalzo wants to know Dino or Syn?
At less than fifty cents an o-ring, i'll change them every time.
rscalzo is offline   Reply With Quote Quick reply to this message
Old 03-28-2010, 05:53 PM   #14 (permalink)
As do I, but the original posters question was why they don't sit correctly or get cut up when new. A simple debur on the inside edge of the hex flats will stop this oring abuse.
Ron
[SIGPIC][/SIGPIC
Old 04-02-2010, 09:33 PM   #15 (permalink)
ellerja's Avatar
ellerja wants to know Dino or Syn?
i just did my first oil change on my 09 RKC.the first 1000 mile was done by the dealer.the plug had some type of white pipe dope on the threads. the oil filter was so tight i had to put some ass on the wrench to get the thing off.so i guess the dealer uses an impact wrench to put the filters on.i hope i havent screw up by using the old o-ring over it looked fine.
ellerja is offline   Reply With Quote Quick reply to this message
