Hi guys,
I've had a short thread on this in the softail section but maybe it actually belongs here.
Last week I did an oil/filter change on my 07 FXST, V&H big radius pipes/fuelpak, 5000 miles (Mechanically stock otherwise). I changed out regular mobil one for the mobil one v twin. Prior to the O/C the bike ran at 220 even on the hottest days, after the change it was about 80deg out and it went up to 240. From searching I see this is not uncommon, I still feel its a little hot.
Since I forgot to stand up the bike when I did the first change I knew there was a little oil left in it, since it only took 2.5 qts instead of 3, I decided to flush the system by doing another o/c. Well I've attached a couple of pics the oil darkened substantially in the 100 miles I rode it. Is it likely the 1/2qt left in the bike caused this or may I be looking at something else. Thanks.
Bah, the system won't allow me to post the same pics twice, even with a name change. The pics are in the thread below. Thanks.
http://www.v-twinforum.com/forums/so...viscosity.html
