Motorcycle.com Classifieds!MBO EnterprisesProCharger.comMotorcycle-Communication
Fuel MotoDan Vance RacingAmerican Side Road CyclePro PadSportbikeTrackGear
Old 09-14-2009, 08:09 PM   #1 (permalink)
Gregmm is on a distinguished road
How Does One Get The Oil Out Of The Oil Cooler When Changing The Oil & Filter?
I have a HD Premium Oil Cooler on my 2005 Road King. I appreciate any comments
-Greg
Gregmm is offline   Reply With Quote
Old 09-14-2009, 08:15 PM   #2 (permalink)
I'm not sure there is a way other than pulling it off and dumping it out.
I have one and have never worried about it, never had a problem and have a pretty good amount on miles on my bike.
There can't be too much oil in there anyway.
'04 Brilliant Silver FLHRSI
Old 09-14-2009, 08:21 PM   #3 (permalink)
Average Dude
YankeeBob's Avatar
One usually doesn't worry about it. Regular oil changes will keep you in good shape, even if there is a little old oil in there.
BTW, Welcome to the VTF. Feel free to stop in the "My Story-The Beginnings" forum and post an introduction.
Deut. 23:12-13
Old 09-14-2009, 08:25 PM   #4 (permalink)
Rebel Son
mungo is on a distinguished road
Yeah, you leave the better part of a quart in the crankcase when you change oil anyway. The additional oil left in the cooler shouldn't make a difference with the proper oil change intervals.
But, if it matter to you, I've seen a device at rallies called "Total Oil Change". Google it and you should find it. It basically is a device that helps you flush out and replace the otherwise left behind oil in an oil change.
--m
2004 Night Train
2009 Street Glide
mungo is offline   Reply With Quote
Old 09-14-2009, 09:51 PM   #5 (permalink)
Doof Toll Pimp
ktwillys's Avatar
ktwillys is on a distinguished road
yep... not enough volume to make much difference....
been running coolers for 30+ years and never once (unless the motor scatered) bothered to drain out the cooler when changing the oil...
To be old and wise,
Here's to old and stupid....
Orthopedic Motto
DC.....
04 FLTRI
SE Welded/Balanced Flywheel
103 Cubes
CP Hi-Comp Pistons
Andrews 54G Gear Drive Cams
S&S Hi-Lift Valve Springs
Timken Conversion
Baisley SuperSTock Heads
V&H True Dual Headers
Bassani Slip-on Mufflers
Thunder Max Ignition System
Feuling Oil Pump
Custom Feuling Cam Plate
ktwillys is offline   Reply With Quote
Old 09-14-2009, 10:31 PM   #6 (permalink)
Coolmaker's Avatar
If there is more than a FEW (4-6) oz's it is sumping...
06FLHRCI
Old 09-14-2009, 11:25 PM   #7 (permalink)
Formerly 04GLIDE
03GLIDE_'s Avatar
I never worry about it.
Old 09-15-2009, 01:46 AM   #8 (permalink)
Ride like the wind
doc ock's Avatar
http://www.roguechopper.com/
04 FLHTI
REDSHIFT TC557 GEAR DRIVE CAM
ZIPPERS THUNDERMAX ECM
V&H TRUE DUALS
KHROME WERKS HP PLUS 100
SE AIR CLEANER
84HP 95TQ
CHROME? AS LITTLE AS POSSIBLE
AMSOIL
14/88
Old 09-15-2009, 02:02 AM   #9 (permalink)
rgrgoog's Avatar
rgrgoog is on a distinguished road
Get a Fueling oil cooler. You change the filter out in it as well with the Oil and your regular filter.
http://fuelingparts.com/wp/index.php
2008 FLHTC, 103"
114ft/lbs Torque, 118 Hp
rgrgoog is offline   Reply With Quote
