Dan Vance RacingAdvanstarMotorcycleShowsRRcycles.comLeslie Kay'sBikeBanditAmerican Side Road CycleCycleGear.comFuel MotoMBO EnterprisesMotorcycle.com Classifieds!
Leslie Kay's
Old 09-14-2009, 07:42 AM   #1 (permalink)
shoveler is on a distinguished road
Primary oil type?
I use HD Syn3 in my primary. Occasionally I have problems down shifting if I come to a stop in a higher gear. A mechanic said the clutch I probably sticking slightly. Any ideas of a better oil to use.
shoveler is offline   Reply With Quote
Old 09-14-2009, 08:25 AM   #2 (permalink)
djmiller is on a distinguished road
I have used Mobil 1 20-50 V-Twin syn. for years no problems.
2009 Ultra Classic
K & N Filter
Vance & Hines Ovals
Vance & Hines FuelPak
96 custom softail
06 Heritage (sold)
01 1200C (sold)
79 sporty (sold0
djmiller is offline   Reply With Quote
Old 09-14-2009, 08:59 AM   #3 (permalink)
Audentes Fortuna Juvat
nightrob's Avatar
Dextron/Mercon Mobil synthetic tranny fluid in mine. Buddys RK had the same thing going on that you have we switched it to the ATF and he hasnt complained about it since. Although it only has been a few hundred miles since the swap!
2007 FXSTB
Friedrich Nietzsche
Old 09-14-2009, 09:28 AM   #4 (permalink)
The Anti-RUB
petrock's Avatar
I seriously doubt your problem is with the oil. More often then not this kind of issue is the clutch adjustment or primary chain adjustment. My bet is on the clutch adjustment.
btw, could you describe the problem your having down shifting? If you mean your in 3rd when you come to a stop and you try to down shift to 1st and it shifts into 2nd but doesn't go to 1st until you move the bike forward slightly (with a little click), that is normal and is not an issue in the primary. Its normal behavior of the tranny itself. Just downshift as your slowing to a stop and you should be fine.
Vivid Black '06 FXSTBI
SE Stage-II 95"
My Two Front Teeph
Old 09-14-2009, 01:44 PM   #5 (permalink)
Ride like the wind
doc ock's Avatar
Before you change primary fluid check the adjustment in the clutch and primary chain. If those are correct should shift fine. I did notice a difference in finding nuetral with ATF and shifting is a little better than before.
04 FLHTI
REDSHIFT TC557 GEAR DRIVE CAM
ZIPPERS THUNDERMAX ECM
V&H TRUE DUALS
KHROME WERKS HP PLUS 100
SE AIR CLEANER
84HP 95TQ
CHROME? AS LITTLE AS POSSIBLE
AMSOIL
14/88
Old 09-14-2009, 02:07 PM   #6 (permalink)
Thread Ender
Pikeslayer's Avatar
Also check that primary is not overfilled.
2007 Street Glide
Old 09-16-2009, 04:21 PM   #7 (permalink)
Are you using the tranny oil in the primary?
Old 09-16-2009, 04:28 PM   #8 (permalink)
Yes, guess I'm getting alzimers. Some times I forget to down shift coming to a stop. Like wanting to tell another rider his saddle bag latch is undone, etc. That is about the only time it happens.
I use Red Line High impact (?name) in the tranny and the tranny is still noisy.
Old 09-17-2009, 10:20 PM   #9 (permalink)
nosmoking962's Avatar
nosmoking962 is on a distinguished road
I just changed out Mobil 1 Synthetic ATF for Amsoil Supershift Synthetic ATF. No noticable difference.
Used to use synthetic 20/50 in the primary and I can tell you for certain, the ATF is far superior.
nosmoking962 is online now   Reply With Quote
Old 09-17-2009, 10:56 PM   #10 (permalink)
Thanks. Does ATF stand for automatic transmissiion fluid?
Old 09-18-2009, 06:20 AM   #11 (permalink)
Yes it does.
Old 09-18-2009, 08:25 AM   #12 (permalink)
nightrob's Avatar
Transmission Fluid not gear lube. It is the Mobil D/M
2007 FXSTB
Friedrich Nietzsche
Old 09-18-2009, 02:14 PM   #13 (permalink)
How often do you change it? Same as the engine oil, 3000 ml.?
Old 09-18-2009, 02:57 PM   #14 (permalink)
RK CRAIG is on a distinguished road
Check your adjustments FIRST, and go from there. As far as primary oil I like SUPERSHIFT ATF from Amsoil.
Tj
RK CRAIG is offline   Reply With Quote
Old 09-19-2009, 09:42 AM   #15 (permalink)
george248 is on a distinguished road
cheap azz ATF... it's just a wet clutch and chain...
george248 is offline   Reply With Quote
