AdvanstarMotorcycleShowsFuel MotoBikeBanditJekillandHyde.euDiamond Bar ChoppersBub EnterprisesSportbikeTrackGearProCharger.comMotorcycle-CommunicationRRcycles.comCustom DynamicsAmerican Side Road Cycle
Old 09-14-2009, 12:39 AM   #1 (permalink)
bkrhoades's Avatar
bkrhoades is on a distinguished road
Evil synthetic oils!!!
Had a pretty good read at HarleyHelp.com. about using syn motor oils in harley's. Bearing skate IS a real problem when using syn oils in harley's. I did'nt believe this at first, so I did some checking around, and sure enough Harley itself does not recomend using syns in their bikes, when pressed for an anwser. Big Dog will void your warranty if you are found to be using syn oils in their bikes! I was told that conventional HD 20w50 is the recomended oil for all harley's to avoid bearing skate. Now I know this will stir up a s*%$# storm with a lot of you guys, so do as I did and check it out yourself. I for one, have always used dino oil in my bike ( 83000 miles ) from the day I bought it with no problems. Syn oils have their place, but I'm not so sure it's in my bike!
I should clairify that this is for twin cam and earlier motors with roller type bearings. Once again HD itself does not recomend using synthetic motor oil in these engines. S&S says you can use syn motor oil, once the warranty is up! When you go to HarleyHelp.com, go to the tech tips link, then to the oils link.
I like the way the lines run down the back of her stockings
bkrhoades is offline   Reply With Quote
Old 09-14-2009, 01:11 AM   #2 (permalink)
Fred1369's Avatar
Fred1369 will become famous soon enough
so why do new Harleys come with Syn from the factory in them? Why does Harley have it's own brand of Syn?
The only bearings you have to worry about are the ones in your muffler.
Fred1369 is offline   Reply With Quote
Old 09-14-2009, 01:59 AM   #3 (permalink)
Infidel
Gulfstream's Avatar
I knew I shouldn't have taken the brown acid...I'm having a flashback to the 70's and 80's!
John Levanger
Old 09-14-2009, 03:24 AM   #4 (permalink)
LOHAWG's Avatar
LOHAWG is on a distinguished road
"bearing skate" havent heard of this one anyone care to elaborate?
94 FLSTN
LOHAWG is offline   Reply With Quote
Old 09-14-2009, 05:54 AM   #5 (permalink)
02 RK,S&S 124" Evo
dog155's Avatar
dog155 is on a distinguished road
Actually years ago this was talked about.Then the issue was that synthetic oil was so slippery that the roller bearing tended to slide over the race rather than roll as they are designed to do.Problem with that is I have been using synthetics in everything I own,since the 70's,and have never had a single problem related to oil too slippery.What do I know,spent 7yrs in the 6th grade!
06 RK,155" R&R TwinCam
02 RK,124" S&S Evo
dog155 is offline   Reply With Quote
Old 09-14-2009, 06:02 AM   #6 (permalink)
Old Fart
OldMsocko's Avatar
OldMsocko is an unknown quantity at this point
Did you ever graduate??
OldMsocko is online now   Reply With Quote
Old 09-14-2009, 06:02 AM   #7 (permalink)
F$ck Google ads
ViennaHog's Avatar
Crawl back in your time capsule
2008 Ultra dark blue pearl
BigBoyz ported street heads
103" SE FT
0.030 Cometic HG
Woods TW 6
V&H Monster Ovals
SE ventilator a/c
TTS
SE compensator
SE race clutch
VPC 92 T
Magura hydraulic clutch
BaggerBrace stabilizer
Full floater front discs
After Douglas Adams RIP
ViennaHog is offline   Reply With Quote
Old 09-14-2009, 06:36 AM   #8 (permalink)
bkrhoades's Avatar
Twin cam and older engines!
Old 09-14-2009, 06:40 AM   #9 (permalink)
bkrhoades's Avatar
Hey Viennapig, I did'nt ask you to flame me. Like I said do some checking on your own. I'm not downing syns, but this could be an issue for some bikes.
Old 09-14-2009, 06:46 AM   #10 (permalink)
Z16Monte
Uhh, The Twinkie IS the latest version of Harley's 45deg twin. Oh and explain to me. If the stuff is so slippery that the rollers won't turn, whats wearing? Can't be the rollers or the races. they're slipping on the oil.
Ed
Z16Monte is offline   Reply With Quote
Old 09-14-2009, 07:38 AM   #11 (permalink)
pirate50's Avatar
pirate50 is on a distinguished road
From the Horses Mouth!
S & S recommends a premium brand of 20W50 oil formulated specifically for motorcycle use for all Long Blocks. In Shovel-Style Long Blocks, 50 or even 60 wt oil is usually acceptable in hot areas where temperatures below 75� are seldom encountered. In S & S's experience it is best to break the engine in with petroleum-based oil and, if a synthetic oil is preferred, change to synthetic after break-in
Pirate
pirate50 is offline   Reply With Quote
Old 09-14-2009, 07:57 AM   #12 (permalink)
Hawg Man's Avatar
Hawg Man is on a distinguished road
Skating Bearings????
I've used Synthetic oil in EVERYTHING I own for the last 25 years, including my lawn tractor AND my old Shovelhead.
I have to admit I've never heard the term before, but if my bearings are skating, they must be enjoying it, because I've NEVER experienced an oil-related failure in anything I own.
My daily driver cage has 166,000 mile on it and does NOT use a drop of oil.
It's been Synthetic all its life.
"A $15,000.00 bike, a new leather jacket, and 25 miles under your butt does NOT make you a biker".
Hawg Man is offline   Reply With Quote
Old 09-14-2009, 09:16 AM   #13 (permalink)
Doof Toll Pimp
ktwillys's Avatar
ktwillys is on a distinguished road
Oil To Slippery............:re drolf::redrolf ::red rolf:
Isnt that the whole idea behind oil..... To Be Slippery....
To be old and wise,
Here's to old and stupid....
Orthopedic Motto
DC.....
04 FLTRI
SE Welded/Balanced Flywheel
103 Cubes
CP Hi-Comp Pistons
Andrews 54G Gear Drive Cams
S&S Hi-Lift Valve Springs
Timken Conversion
Baisley SuperSTock Heads
V&H True Dual Headers
Bassani Slip-on Mufflers
Thunder Max Ignition System
Feuling Oil Pump
Custom Feuling Cam Plate
ktwillys is online now   Reply With Quote
Old 09-14-2009, 09:35 AM   #14 (permalink)
I like children - fried.
plongson's Avatar
plongson is on a distinguished road
Actually, bearing skate is real, and it is a problem in roller and ball bearings that are not LOADED heavily enough. If the application of the bearing to the designed load is not matched, skate can occur, usually when the bearing is sized way too large for the load. The lubricant can have an effect on skate. It is highly unlikely that the bearings in our v-twins motors are so large vs. load they will skate with syn. lubes...
2005 Road King Classic FLHRCI 88"
HQ-34's
HQ Pro-Tune
S&S Geardrive
Baisley LMR-2 15% pressure spring
Arlen Ness Big Sucker
Python pipes
And YES, I have the SERVICE & PARTS MANUAL
plongson is offline   Reply With Quote
Old 09-14-2009, 09:38 AM   #15 (permalink)
springer-'s Avatar
Hey Viennapig, ......
This is a warning in regard to what you call others.
Originally Posted by Forum Rules
2. Flaming or harassing other members will not be tolerated.
