Motorcycle-CommunicationCustom DynamicsSportbikeTrackGearAdvanstarMotorcycleShowsDiamond Bar Choppers
RRcycles.comFuel MotoBub EnterprisesProCharger.com
Old 09-01-2009, 10:55 PM   #1 (permalink)
midnight sporty's Avatar
midnight sporty is on a distinguished road
anyone running the harley softail cooler?
i want the vertical oil cooler for my crossbones. just wanted to know how the fit and finish was on it, and how good it works..
08 crossbones
hillside 107
woods tw8 cams
hillside stage 3 heads
s&s roller rockers
s&s adj pushrods
55 hpi throttle body
larger injectors
D&D fatcat-perf baffle
vp92t
hillside air filter
230 ccp
not one ounce of pinging
hillside cycle...
midnight sporty is offline   Reply With Quote
Old 09-01-2009, 11:06 PM   #2 (permalink)
tazdevl20062008 is on a distinguished road
I wouldn't go with the HD kit. I'm not a big fan of kits that use regular hose and hose clamps that fit over the brass fittings. Plus JAGG sells kits that are about $100 cheaper than the HD, and probably better. That and HD chrome sucks. If you want to do it, I would go with a higher end kit that used braided steel line with the ends attached through AN fittings. Motorcycle Innovations Bad Boy Super Cooler comes to mind, although you'll pay twice as much for it v. the Jagg. Another option is to buy the oil cooler kit, and buy your own braided lines and substitute them for the rubber hose in the kit. Good luck. The link has some good info.
http://www.jpcycles.com/Search/Searc...rt&state=&Ntx=
tazdevl20062008 is offline   Reply With Quote
Old 09-01-2009, 11:25 PM   #3 (permalink)
Old married guy
vindex1963's Avatar
Pretty good deal for under $200
Edit: It doesn't include the thermostat
2009 FLHTCU Ultra Classic
Vance & Hines Fuel Pak
Vance & Hines Slip-Ons
S/E air cleaner
Stage 1 download
Mobil 1 everything
Old 09-02-2009, 12:52 AM   #4 (permalink)
ponderopa's Avatar
ponderopa is on a distinguished road
I don't see the jag being much cheaper. The HD sells for around 260 on ebay with adapter. The jag is 174 w/o adapter, which is around 70-80 bucks. Not saying which is better; I'm buying one over the winter but haven't decided which.
ponderopa is offline   Reply With Quote
Old 09-02-2009, 01:32 AM   #5 (permalink)
i like the badboy kit very much, but the adapter doesent have the thermostat built in it.. i like the dual cool 2 and have it powdercoated black to match the bike. but i dont know how good they work. my friend can cut the ends off and run fittings if i want..
08 crossbones
hillside 107
woods tw8 cams
s&s roller rockers
s&s adj pushrods
larger injectors
vp92t
hillside air filter
230 ccp
hillside cycle...
