Diamond Bar ChoppersMotorcycle.com Classifieds!MBO EnterprisesLeslie Kay'sDan Vance RacingBub EnterprisesBikeBanditJardineProducts.comRRcycles.com
SportbikeTrackGear
Old 08-30-2009, 08:08 PM   #1 (permalink)
hodshire is on a distinguished road
red line oil
I just got two redline v-twin power packs from a buddy that wrecked his bike. I always used amsoil in my shovel's and evo but when I got my first twin cam amsoil made the top end tick to much and I switched to mobil-1 v-twin. I just got the 1000 mile service done on my 09 fatboy and was going to switch to mobil at 1500 but I am going to go with redline because of the price (free). Does anyone use this oil, primary and tranny fluid and how does it compair to mobil. If I like it I might switch my 06 roadking over to it also. I never have had a oil related problem with either amsoil or mobil but my friend says it made his bike quieter than with mobil?
hodshire is offline   Reply With Quote
Old 08-30-2009, 09:24 PM   #2 (permalink)
I've used it in the past with no problems. It's as good as the other 2 oils you mentioned,
so it just comes down to personal preference.
_______________
04 softail standard
Baisley-Axtell 117 - Baisley pro street heads - Baisley hybrid injection
Bob Wood TW-8 - Darkhorse crank - P.M. Hydraulic clutch
P.M. Villain wheels-rotors
Builder - hdryder
Phat117 is offline   Reply With Quote
Old 08-31-2009, 12:11 PM   #3 (permalink)
Thanks I assumed that red line had a good product, so I will use the power pak and save some money on this oil change.
Old 08-31-2009, 12:14 PM   #4 (permalink)
midnight sporty's Avatar
midnight sporty is on a distinguished road
thats odd. everyone says they here the ticking more with amsoil. and i have pretty radical woods cams and i just changed last week to amsoil and i cant here a thing compared to the spectra oil that was in it..
08 crossbones
hillside 107
woods tw8 cams
hillside stage 3 heads
s&s roller rockers
s&s adj pushrods
55 hpi throttle body
larger injectors
D&D fatcat-perf baffle
vp92t
hillside air filter
230 ccp
not one ounce of pinging
hillside cycle...
midnight sporty is offline   Reply With Quote
Old 08-31-2009, 08:04 PM   #5 (permalink)
Yes I thought it was strange also but with amsoil my rockers or lifters did tick more. I have used amsoil for years and still use it in my wifes suzuki and it runs quiet and smooth as silk. I also used it in my v-rod up till I traded it in on my 09 fatboy but in my two twin cams it made them tick louder. I used it in my evo up till I sold it with 94k and never had a problem. I switched to mobil-1 v-twin and it was quieter, so I have used it in my twin cams since.
Old 08-31-2009, 08:50 PM   #6 (permalink)
Formerly 04GLIDE
03GLIDE_'s Avatar
Redline is my favorite oil. I just can't find it around here anymore. I run it when I can find it.
Old 09-01-2009, 07:03 AM   #7 (permalink)
I never see their products around my area. My friend got it on line like I do for amsoil.
Old 09-01-2009, 11:46 AM   #8 (permalink)
yeah im gonna try some redline.. see if i like it..
08 crossbones
hillside 107
woods tw8 cams
s&s roller rockers
s&s adj pushrods
larger injectors
vp92t
hillside air filter
230 ccp
hillside cycle...
Old 09-01-2009, 12:02 PM   #9 (permalink)
Join MRF/ABATE
Bluzmn59's Avatar
Bluzmn59 is on a distinguished road
I order Redline by the case from this place.
Life is hard. It's really hard if you're stupid.
http://i165.photobucket.com/albums/u65/Bluzmn59/BeachSig.jpg
1959 FLH
2007 FLSTSC
2009 FLHX
My Photo Albums
Bluzmn59 is offline   Reply With Quote
Old 09-01-2009, 03:55 PM   #10 (permalink)
ill tell you ive ran amsoil all day today. and i honestly like it.. but i really would like to try the redline thanks for letting me know where you order it from.. ill try it..
08 crossbones
hillside 107
woods tw8 cams
s&s roller rockers
s&s adj pushrods
larger injectors
vp92t
hillside air filter
230 ccp
hillside cycle...
Old 09-01-2009, 04:41 PM   #11 (permalink)
I think the last time I ordered some it was from myoilshop.com.
Don't expect any miracles, it's good oil, just like Amsoil and others.
_______________
04 softail standard
Builder - hdryder
Old 09-01-2009, 06:58 PM   #12 (permalink)
mvent is on a distinguished road
Phat, well said, none of them are miracle oils, if your top end is noisy for whatever reason, none of the oils will cure it, thicker may help, but thats it.
mvent is offline   Reply With Quote
Old 09-01-2009, 10:58 PM   #13 (permalink)
eh i rode all damn day today. and so far im loving the amsoil. theres no more top end noise. wich is odd. cus its saposed to make it louder.
08 crossbones
hillside 107
woods tw8 cams
s&s roller rockers
s&s adj pushrods
larger injectors
vp92t
hillside air filter
230 ccp
hillside cycle...
Old 09-01-2009, 11:05 PM   #14 (permalink)
Do the math, first !!
thedriver's Avatar
thedriver is on a distinguished road
i set my rocker end play to .004 from .018, then 500 miles later changed from redline 50w to redline 20w60. BIG fan of Redline. between the 2 changes it's much quieter. 4K miles on Sturgis trip , no problems. that's my story and i'm stikin to it. if that many people have said " Amsiol makes my top end more noisy, compared to other oils ," i don't know, can they all be wrong, or Amsiol haters. just asking. i am not
[ 07 Ultra 103 CI - SE\AC - cast flat tops - BigBoyz heads - 9.5 CR - .034 sqiush - SE255 cams - SE cam plate - Baisley spring - SE roller rockers - SERT - 30 tooth trans - IDS - Fatcat QB -
thedriver is offline   Reply With Quote
Old 09-02-2009, 08:41 AM   #15 (permalink)
I rode about 100 miles on redline oil change yesterday. I did not notice my bike being any quieter with redline over the mobil but it did not get any louder either. The place that bluzmn59 posted is where my friend ordered his (now mine). I use amsoil in other bikes and I like it but it did make both of my twin cams valve trains louder, just a simple fact with mine. I can hear a change in the engine and someone else can not, more power to them. I think most synthetic oils are more than likely great but I am sticking to amsoil, mobil, redline or belray. Thanks for all the input.
