JekillandHyde.euMotorcycle.com Classifieds!AdvanstarMotorcycleShows
ProCharger.comJardineProducts.comRRcycles.comMotorcycle-CommunicationBikeBanditMBO EnterprisesDan Vance Racing
Bike Bandit
Old 08-26-2009, 03:05 PM   #1 (permalink)
blacktrain13 is on a distinguished road
Best place to purchase oil/filter?
Where is the best place that you have found to purchase oil filter engine oil, and all other engine fluids? My 5000 service is coming up soon and I plan on changing all the recommened fluids myself. I have a 2004 FXSTBI.
blacktrain13 is offline   Reply With Quote
Old 08-26-2009, 05:13 PM   #2 (permalink)
Ride like the wind
doc ock's Avatar
This is a very open ended question. You'll get alot of opinions. What fluids do you plan on using? My personal conviction is to stay away from wal-mart. Most automotive part centers will have what you need. Or call George, a site sponser for Amsoil.
04 FLHTI
REDSHIFT TC557 GEAR DRIVE CAM
ZIPPERS THUNDERMAX ECM
V&H TRUE DUALS
KHROME WERKS HP PLUS 100
SE AIR CLEANER
84HP 95TQ
CHROME? AS LITTLE AS POSSIBLE
AMSOIL
14/88
Old 08-26-2009, 07:08 PM   #3 (permalink)
Formerly 04GLIDE
03GLIDE_'s Avatar
I have used the Bosch 3330 filter for many years with good results. I put 75,000 miles on my 04 running them. I am running one on my 03 right now. I am not even going to recommend an oil there are so many to choose from. Any good syn 20/50 will do though. Preferably one designed for motorcycles. ATF in the primary and gear oil in the trans.
Old 08-26-2009, 09:43 PM   #4 (permalink)
HDSG is on a distinguished road
Best Place to Buy Oil & Filter
You asked so this is my opinion:
Call George Douglas ( Site Sponcer ), set up an account. Have the following delivered to your door step.
Order the following:
5 Qts of Amsoil 20/50 for Harley. 4 for the oil change and a little left for topping off between oil changes.
1 Qt. Severe Gear 75/110 for the Trans.
1Qt. Synthetic ATF fpr the Primary.
Change fluids per Service Manual ( a must).
Fill tank with gas and ride the hell of the thing.............Really
HDSG is offline   Reply With Quote
Old 08-26-2009, 09:45 PM   #5 (permalink)
I'm with ya brother............
Old 08-26-2009, 11:58 PM   #6 (permalink)
Ride like the wind
doc ock's Avatar
couldn't have said it better myself.
04 FLHTI
V&H TRUE DUALS
SE AIR CLEANER
84HP 95TQ
AMSOIL
14/88
Old 08-27-2009, 12:45 AM   #7 (permalink)
hbmc's Avatar
So I went down to pepboys and looked at the different size oil filters as I was told on here that frahm was the worst and I looked at the others and I got to tell you more filter seems like a better idea then less filter... I use the Framm heavy duty ph2870A and I cant see the how one is better then the other other then micro filter (not the beer!) thats micro brew but the dense of the filter and then you gotta think about getting to dense as the pressure will be affected, no? To get around safety orange I grab a rattle can and shoot before I start and dry by the time I am ready to spin it on. I have been in my motor a few times and it is pretty shiny in there ... I know, I know tell me about stats and graphs I am just using experience in the California Desert.
1991 flstf 'fat-boy
2-1 White "E-pipe"
29 tooth Andrews pully
Old 08-27-2009, 05:10 AM   #8 (permalink)
amsoilpete's Avatar
amsoilpete is on a distinguished road
Blacktrain,
Just as HDSG and doc ock said,
contact George Douglas, www.oilhelp.com and he will set you right up. Product will be delivered to you doorstep and you will get it for the same cost as a dealer.
Personally I use the 20W-50,(MCV), for the engine, Super Shift,(ART), for the primary, and Severe Gear 75W-140,(SVO), in the trans.
I use this combo in all my customers bikes,(Evo's and TC's) with no problems and all positive feedback.
Don't forget to get an EaOM134, (black) or 134C, (chrome) filter.
amsoilpete is offline   Reply With Quote
Old 08-27-2009, 07:50 AM   #9 (permalink)
Doof! There it is.....
'05Train's Avatar
'05Train is on a distinguished road
I use 75/90 for the transmission, but Amsoil's the way to go. George'll have it on your doorstep two days after you order the stuff. Make sure you order a filter and filter wrench from him too.
'05 Vivid Black Night Train
Lots o' black
103 by Dave at JD's
116.70/116.01 SAE
'05Train is online now   Reply With Quote
Old 08-27-2009, 08:07 AM   #10 (permalink)
You are correct, I forgot the Amsoil Filter. I use them and get them from George Douglas also. Thank you for mentioning the filter.
Old 08-27-2009, 08:32 AM   #11 (permalink)
thrasher's Avatar
thrasher is on a distinguished road
I use Mobil 1 full synthetic in the crankcase, Redline Heavy Shockproof in the transmission, and ATF in the primary. I'm running a Baker DD6 transmission and a Rivera Primo Pro clutch.
K&N oil filters for me. They are excellent filters and I like the hex nut on the end for easy removal,... especially with the engine oil cooler right there in the way.
Did the Corinthians ever write back?
thrasher is offline   Reply With Quote
Old 08-27-2009, 10:46 AM   #12 (permalink)
Finally
Strick28 is on a distinguished road
Yep and I don't have to order it. $24 for a 5 qt jug @ Walmart for Mobil 1 Syn. The other items @ the local auto parts...
"It's The Mirrors"
Strick28 is offline   Reply With Quote
Old 08-27-2009, 12:19 PM   #13 (permalink)
That's the most important part. Should be the 11th commandment: Thall shall not shop at Wall Mart!
Aside from that, George is a stand up guy that offers good service to forum members.
_______________
04 softail standard
Baisley-Axtell 117 - Baisley pro street heads - Baisley hybrid injection
Bob Wood TW-8 - Darkhorse crank - P.M. Hydraulic clutch
P.M. Villain wheels-rotors
Builder - hdryder
Phat117 is offline   Reply With Quote
Old 09-02-2009, 09:56 AM   #14 (permalink)
NightCross is on a distinguished road
I decided to change back to Dino fluids.
Primary: Rotella 15w40 (2.69 quart wallyworld)
Gear Box: Rotella 85w140 Heavy Duty (4.69 qt wallyworld_
Engine: Valvoline VR-1 SAE 50 (3.98 qt O'Reily's)
Fliter: Wix pn 51348 (3.49 O'Reily's)
NightCross is offline   Reply With Quote
Old 10-11-2009, 08:18 PM   #15 (permalink)
mje9999 is on a distinguished road
Hey NightCross, where did you get the cross over to Wix? I've been stuck using fram PH6022 motorcycle filters out of Advance for around 6 bucks.
Primary: Castrol ATF Multi-vehicle it's a synthetic blend
Trans: Mobil 1 75W / 90
Engine: Mobil 15W / 50 wallyworld
Filter: Fram PH6022
mje9999 is offline   Reply With Quote
