08-23-2009, 07:47 AM
oil change on a 103"
I just had a 103" built in my 07 ultra with the andrews 54 cams and heads. I was told to change the motor oil every 1200 miles. Does that sound a littleover kill? I want to do what is best for the motor. Thanks for any info
Save A Biker Shoot a Doe!!!!!
08-23-2009, 11:22 AM
Old married guy
First oil change maybe? I bet not everyone.
08-23-2009, 01:16 PM
semi-retired
i would change it at 50,150 and then go to synthetic.Get a jagg oil cooler and chage every 4000 miles or 4 months.
I can't means I won't!
08-23-2009, 02:06 PM
Formerly 04GLIDE
on a new motor I change at 100.200,500 and 1000. Every 5,000 after that. And I just use cheap Havoline 20/50 for the first 3 changes. Good syn at 1,000.
08-23-2009, 05:27 PM
first oil change @ 500, second @ 1000 then every 3000 miles after that..
08-23-2009, 07:44 PM
Iron Butt, SS2000
First change at 500 miles then change to synthetic and change it every 5,000 after that. I worked mine to where it's due for a change at every multiple of 5K on the odometer. OOPS, I just noticed I am a little overdue for my 55K oil change, gotta go!
08-23-2009, 10:58 PM
Do the math, first !!
Ya, thats the way to go.  been doin it like that for years. never a problem. make sure all the break in cr@p gets out of the engine. then pick your poison ( good syn oil ) and ride the hell out of it. enjoy !! my $.02
[ 07 Ultra 103 CI - SE\AC - cast flat tops - BigBoyz heads - 9.5 CR - .034 sqiush - SE255 cams - SE cam plate - Baisley spring - SE roller rockers - SERT - 30 tooth trans - IDS - Fatcat QB -
08-24-2009, 12:22 AM
mooooving out!
What he said.
43%er
Bi-polar and loving it!!
Bi-polar and hating it!!
95" w/ KB pistons (flattops)
HQ575 cams
Atwood's Road Warrior Heads
.030 head gasket
SuperTrapp Supermeg 2in1
"43" points cover
TRW rear mount
obligatory Baisley Spring
Just sayin..........
08-31-2009, 03:06 AM
Engine oil is a engine cleaner and not only a lube. Because of E10 alcohal fuels and other stuff entering your engine and into your oil you should change it often. I change mine about every 2000 miles or so.
08-31-2009, 06:01 PM
I'm a Rebel. I change my oil every 5,000 miles and I use Mobile 1 15w-50. When I did my 95" Head Quarters build I changed my oil at 500 miles and then went syn and every 5,000 miles after that. Changing a good synthetic oil any sooner than 5,000 miles is wasting perfectly good oil. There are guys who have sent out samples of their oil for testing and they always come back great at 5,000 miles.
Blue and Silver Triglide Powered By The Underpowered Hot Running Bike Builders Of Harley Davidson.
09-01-2009, 01:46 AM
The Anti-RUB
The HD service manual states to change the engine oil every 5k miles. More often then that is pure overkill and a waste of time/money/oil.
Originally Posted by xtractor
Because of E10 alcohol fuels and other stuff entering your engine and into your oil you should change it often.
There are no studies that I am aware of that show that to be the case. All I've seen (on this forum and others) are uninformed people expressing their opinions, not facts.
Vivid Black '06 FXSTBI
SE Stage-II 95"
My Two Front Teeph
