Pro PadBub EnterprisesAdvanstarMotorcycleShowsBikeBanditFuel MotoMotorcycle-CommunicationDiamond Bar Choppers
Pro Pad
Old 08-01-2009, 10:20 AM   #1 (permalink)
sportcruiser is on a distinguished road
Is ATF in the Primary OK with MoCo?
I have read many of the posts here and am convinced ATF will improve shifting and eliminate the cold start clutch drag that occurs in my '09 FLHT.
The question I have is whether this is viewed as a legitimate choice by MoCo. I know all of the oil debates rage on, but to me, this is different as an ATF is certainly a different fluid than anything Harley recommends. So, if I have ATF in the primary and have a failure, and the dealer drains that obviously different, red fluid out. Am I screwed?
sportcruiser is offline   Reply With Quote
Old 08-01-2009, 10:32 AM   #2 (permalink)
Audentes Fortuna Juvat
nightrob's Avatar
Drain it before you take it to the dealer if your worried about it. But I must say I run mobil atf in mine and it has never performed better. I have several thousand miles on it!!
2007 FXSTB
Friedrich Nietzsche
Old 08-01-2009, 10:34 AM   #3 (permalink)
Dave63's Avatar
Do they recommend it? No....they'll tell you to use Syn3.
Will they try to blame it on the ATF? Count on it.
Will it cause a failure? Highly doubt it.
Dave
Old 08-01-2009, 10:41 AM   #4 (permalink)
Old married guy
vindex1963's Avatar
Interesting question finally in the oil section!!! I'm going to watch to see where this goes. I used ATF in my 04 but now have an 09. I really like it and will continue to use it.
edit: Does it have any effect on the auto tensioner?
2009 FLHTCU Ultra Classic
Vance & Hines Fuel Pak
Vance & Hines Slip-Ons
S/E air cleaner
Stage 1 download
Mobil 1 everything
Old 08-01-2009, 10:59 AM   #5 (permalink)
Dave63's Avatar
None that I've seen in 3500 miles of use. I use Type-F. Seems to make the clutch grab/feel better. Placebo effect, maybe.
Dave
Old 08-01-2009, 11:09 AM   #6 (permalink)
Old married guy
vindex1963's Avatar
I don't think so. In my 04 it made clutch engagement MUCH smoother and no drag on disengagement.
S/E air cleaner
Stage 1 download
Mobil 1 everything
Old 08-01-2009, 01:44 PM   #7 (permalink)
Superglidebob is on a distinguished road
I gotta think that if ATF works as well as in does in automatic transmissions with all the complex stuff going on in there,(complex to me, anyway!), using it in a relatively simple primary is going to be fine.
I tried Type F and I could believe the difference. I also think it will be fine with my M-6 tensioner.
I cant see going back to any other fluid!
Superglidebob is offline   Reply With Quote
Old 08-01-2009, 01:57 PM   #8 (permalink)
Moneygreen
arealinvestor is on a distinguished road
Wow very interesting???
Craig G.
Old 08-01-2009, 02:02 PM   #9 (permalink)
Guess I'll give it a shot.
Old 08-01-2009, 02:16 PM   #10 (permalink)
dynarule's Avatar
dynarule is an unknown quantity at this point
Have you noticed any difference with metal shavings on the drain plug between Atf and and whatever else you were using?
dynarule is offline   Reply With Quote
Old 08-01-2009, 02:28 PM   #11 (permalink)
Old married guy
vindex1963's Avatar
It is as far as the MoCo bitching about it.
S/E air cleaner
Stage 1 download
Mobil 1 everything
Old 08-01-2009, 02:33 PM   #12 (permalink)
Moneygreen
Has anybody tried Torco's synthetic blend for the primary???
Craig G.
Old 08-01-2009, 02:41 PM   #13 (permalink)
Dave63's Avatar
No. I dropped a new chain and HD auto tensioner in at the same time in my 1995 Dyna. Magnetic plug was neither worse or better then before, despite fluid change.
Dave
Old 08-01-2009, 07:25 PM   #14 (permalink)
auto tensioner is spring loaded ratchet, so no effect whatsoever. a thicker oil may quieten the roaring noise after the auto tensioner jumps another notch, but no harmful effect. you can tell when the tensioner has made another notch on the ramp, you will hear the tight chain whirring for a couple hundred miles. but you hear the same noise with amsoil, syn 3, mobil 1 , or atf.
Old 08-01-2009, 07:33 PM   #15 (permalink)
Dave63's Avatar
Well....cause you're not using "their" fluids.
Geez....look how they whined like a bitch with a skinned knee over synthetics and "needle bearing skipping/flat spot" until they came out with their own synthetic (*cough*semi-synthetic*cough*cough*) oil.......
Dave
