SportbikeTrackGear
JardineProducts.comAmerican Side Road CycleCustom DynamicsBikeBanditPro PadMotorcycle.comDiamond Bar ChoppersProCharger.comMotorcycle-CommunicationRRcycles.comMBO Enterprises
Old 07-25-2009, 10:32 PM   #1 (permalink)
CaptVic's Avatar
CaptVic is on a distinguished road
Dino Oil
I just drop the oil in the softail 117 build thinking I had 3 or more quarts of dino oil left. (NO DINO OIL). So here is the question. I have 900 miles on the build now. Is it to soon to go to AmsOil Synthetis 20W-50? Thanks. Want to ride the bike tomorrow and will not be able to buy dino oil till monday.
O7 FLSTC & 2010 FLHTK
http://i221.photobucket.com/albums/d...c/P9190003.jpg
CaptVic is offline   Reply With Quote
Old 07-25-2009, 11:38 PM   #2 (permalink)
yes, you could use it from day one.
Mtclassic is online now   Reply With Quote
Old 07-25-2009, 11:39 PM   #3 (permalink)
Do the math, first !!
thedriver's Avatar
thedriver is on a distinguished road
900 miles is plenty. but, is that the first oil change since the new build ??
[ 07 Ultra 103 CI - SE\AC - cast flat tops - BigBoyz heads - 9.5 CR - .034 sqiush - SE255 cams - SE cam plate - Baisley spring - SE roller rockers - SERT - 30 tooth trans - IDS - Fatcat QB -
thedriver is offline   Reply With Quote
Old 07-26-2009, 12:12 AM   #4 (permalink)
CaptVic's Avatar
No that is going to make the Number 4. Did one at 25 miles, One 100 miles, one at 500 miles.
Old 07-26-2009, 12:19 AM   #5 (permalink)
Ride like the wind
doc ock's Avatar
You must like to change oil.
04 FLHTI
REDSHIFT TC557 GEAR DRIVE CAM
ZIPPERS THUNDERMAX ECM
V&H TRUE DUALS
KHROME WERKS HP PLUS 100
SE AIR CLEANER
84HP 95TQ
CHROME? AS LITTLE AS POSSIBLE
AMSOIL
14/88
Old 07-26-2009, 01:54 AM   #6 (permalink)
Bike Builder
syco's Avatar
syco is on a distinguished road
Oil is cheap!On a build that is over $10k I think I would be changeing it just like Captvic is doing while breaking it in...At least it makes you feel good if not anything else. I,m following Captvic with my breakin procedure to.
R&R/Hyperformance 124" 143hp/144tq SAE
R&R billet heads
R&R 5 piece crank
R&R two piece Cam plate
Dave Makie 630G CAM
Hyperformance ductile Iron cylinders
11.53:1 comp.
55mm Max FlowHPI
D&D Borzilla
Baker OD6 tranny
Baker Plus 1 oil pan
Fueling pump
syco is online now   Reply With Quote
Old 07-26-2009, 01:55 AM   #7 (permalink)
Bike Builder
syco's Avatar
I,d say your ready for the Amsoil go for a ride tomorrow and have fun.Be safe!
R&R billet heads
R&R 5 piece crank
Dave Makie 630G CAM
11.53:1 comp.
55mm Max FlowHPI
D&D Borzilla
Baker OD6 tranny
Fueling pump
Old 07-26-2009, 09:15 AM   #8 (permalink)
Let er rip!
oh1deuce's Avatar
oh1deuce is on a distinguished road
Valvoline VR-1 straight 50w
Smooth as a wet....
R&R St. V cast heads
R&R 615/585's
R&R Cam plate
R&R Roller Rockers
oh1deuce is offline   Reply With Quote
Old 07-26-2009, 03:08 PM   #9 (permalink)
http://www.v-twinforum.com/forums/en...t-miracle.html
