SportbikeTrackGearPro PadCycleGear.comMotorcycle.com
Motorcycle-CommunicationCustom DynamicsAmerican Side Road Cycle
Old 07-20-2009, 09:57 PM   #1 (permalink)
airportcopper is on a distinguished road
Question oil fill
i just recently changed my oil from hd 20 50 to amsoil 2050, so far im happy with the oil, dont know if its worth the extra cash don't really notice a difference. the only problem is on the fill stick its above the fill line when the bike is hot i used a hd filter.. i put four quarts in like hd called for by the way the bike is a 08 road king classic.. should i be nervous about the oil above the fill line..
airportcopper is offline   Reply With Quote
Old 07-20-2009, 10:29 PM   #2 (permalink)
Do the math, first !!
thedriver's Avatar
thedriver is on a distinguished road
yes, these HDs have enough problems with oil stuff ( venting & sumping ) overfilling just adds to it. the best way to fill is 1\2 qt low cold on the stand. thats what i do, and i'm sure many others as well.
[ 07 Ultra 103 CI - SE\AC - cast flat tops - BigBoyz heads - 9.5 CR - .034 sqiush - SE255 cams - SE cam plate - Baisley spring - SE roller rockers - SERT - 30 tooth trans - IDS - Fatcat QB -
thedriver is online now   Reply With Quote
Old 07-21-2009, 12:45 AM   #3 (permalink)
Audentes Fortuna Juvat
nightrob's Avatar
3 to 31/2 quarts will usually do it unless you drained the crankcase also, which you shouldnt do. Anyway get a turkey baster or oil sucker from your auto parts store and suck the excess out.
2007 FXSTB
Friedrich Nietzsche
Old 07-21-2009, 09:44 AM   #4 (permalink)
HDSG is on a distinguished road
Good advice................never............never overfill a Harley. Change oil and filter and add 3.25 quarts, ride bike until it is HOT and add oil until it reads just below full.
HDSG is online now   Reply With Quote
Old 07-21-2009, 09:52 AM   #5 (permalink)
BigMo
Mohead1's Avatar
Totally agree with others, never overfill, I put in 3 then warm it up (ride easy around the block) and slowly bring up on the stick. I usually keep it 1/4 to 1/3 of a quart low. I have gone as much as a 1/2 qt. low. This helps with the blowby oil, and it doesnt affect the motor any. I have done this for quite some time with several internal inspections showing no probs........
BigMo
Old 07-21-2009, 10:02 AM   #6 (permalink)
FOG
trooper113's Avatar
trooper113 is on a distinguished road
Don't know about your '08 RK, but my '07 Ultra calls for 3 1/2 quarts at oil/filter change.
trooper113
NRA Endowment Member
AMA Member
trooper113 is offline   Reply With Quote
Old 07-21-2009, 09:02 PM   #7 (permalink)
thanks
i called the dealer asked them what they thought they told me to run the bike for about fifteen mins than check the oil level on its jiffy stand.. i checked it and it was just below the fill line.. problem solved..
Old 07-21-2009, 09:06 PM   #8 (permalink)
NHFree1's Avatar
NHFree1 is on a distinguished road
My dip stick has two sets of marks....cold engine and hot engine. I use the cold engine marks when changing the oil. Takes exactly 3-1/2 qts to make it happy. I've looked at it when stopped on long rides and it never goes above the high mark in the hot engine scale.
"To sit back hoping that someday, some way, someone will make things right is to go on feeding the crocodile, hoping he will eat you last - but eat you he will." – Ronald Reagan
NHFree1 is offline   Reply With Quote
