Sure the manual states 10W-40 if lowest ambient temperature is below 40 deg. I would run 20W-50 till that time comes. As far as using M1 10w-40, should not pose any problems because the reason we run "V-Twin" oil is for the heat break down. And the cold riding months in the Dakotas should be a short time, before the bike gets put away for the winter, and you will be putting 20W-50 back in so the oil will last a long time. If I lived where it was cooler most of the time I might run 10w-40 all the time.
04 FLHTI
REDSHIFT TC557 GEAR DRIVE CAM
ZIPPERS THUNDERMAX ECM
V&H TRUE DUALS
KHROME WERKS HP PLUS 100
SE AIR CLEANER
84HP 95TQ
CHROME? AS LITTLE AS POSSIBLE
AMSOIL
14/88
