Diamond Bar ChoppersAdvanstarMotorcycleShowsMotorcycle-CommunicationMotorcycle.com Classifieds!
SportbikeTrackGearFuel MotoPro PadBub Enterprises
Pro Pad
Old 06-24-2009, 07:52 PM   #1 (permalink)
DRG
DRG's Avatar
DRG is on a distinguished road
Breakdown
When oil breaks down at a certain temp has all the qualities of the oil been comprimised. Should it be changed at that point.
Thanks Dave
DRG is offline   Reply With Quote
Old 06-25-2009, 03:18 AM   #2 (permalink)
Infidel
Gulfstream's Avatar
By the way you formulated that question I think you know the answer...yes!
John Levanger
Old 06-25-2009, 06:45 AM   #3 (permalink)
Gary7's Avatar
Gary7 is on a distinguished road
Thanks Dave
"Breakdown" from high oil temps is typically used to denote oxidation, and it is not a binary state, i.e., good/bad. Oxidation occurs to a greater or lesser extent over the life of the oil no matter what the operating conditions and is one of the reasons the oil has to be changed. More oxidation = more frequent oil changes. But short of coolant contamination (only possible on a V-Rod), water ingress which causes contamination, or a mechanical failure that results in particulate contamination (and if that happens, oxidation is the least of your worries), I can't think of anything that would require an immediate oil change.
If you know you had a temp spike that pushed the oil temp up excessively, you have shortened the useful life of the oil and it's probably a good idea to cut that particular change interval short. But an immediate oil change is not necessary, IMO.
Gary7 is offline   Reply With Quote
Old 06-25-2009, 07:33 AM   #4 (permalink)
DRG
DRG's Avatar
The reason I ask is there was another thread that somebody mentioned that dino broke down at 250 and syn at 300. This seems low to me and was wondering if the oil reached these temps would it change the characteristics of the oil. Does it just change at temp or is it effected from that point on. Sorry for not explaining it better.
Dave
Old 06-25-2009, 07:54 AM   #5 (permalink)
Gary7's Avatar
Dave
All oil begins to oxidize as its bulk temperature increases. The higher the temp, the greater the level of oxidation. There is no threshold temp at which dino oil completely "breaks down," nor is there one for synthetics. Synthetic oils will resist oxidation at higher temps, but they too will oxidize.
An oil that never sees bulk temps over 250F will last a lot longer than oil that routinely sees temps over 250F. For an oil to suffer the least from temp related oxidation it needs to quickly get up to operating temp and always operate in a range between 150F and 250F.
Old 06-25-2009, 11:32 AM   #6 (permalink)
DRG
DRG's Avatar
Thanks for the info Gary.
Dave
