Diamond Bar ChoppersMBO EnterprisesBikeBanditPro PadDan Vance RacingProCharger.comRRcycles.comMotorcycle-Communication
Old 06-17-2009, 09:29 PM   #1 (permalink)
rob71458 is on a distinguished road
Draining Engine case sump
I am going to change the oil on my bike to a different brand and viscocity. I thought it may be a good idea to drain the case sump at the same time, to reduce the dilution of the new oil. Is this a problem? Will the pump cavitate on start up?
rob71458 is offline   Reply With Quote
Old 06-17-2009, 09:56 PM   #2 (permalink)
shovelmike's Avatar
shovelmike is on a distinguished road
Don't Do It!
Do not try to drain the sump, what little oil is there won't cause near the trouble you can cause by messing with that plug!
This is my Granddaughter, Sky age 7. She can't walk,talk, or feed herself due to brain injury but look at that smile. It makes most of our troubles seem quite insignificant.
shovelmike is offline   Reply With Quote
Old 06-17-2009, 10:24 PM   #3 (permalink)
What kind of trouble?
Old 06-18-2009, 01:17 AM   #4 (permalink)
Ride like the wind
doc ock's Avatar
http://www.v-twinforum.com/forums/en...scavenger.html If you must get out every drop.
04 FLHTI
REDSHIFT TC557 GEAR DRIVE CAM
ZIPPERS THUNDERMAX ECM
V&H TRUE DUALS
KHROME WERKS HP PLUS 100
SE AIR CLEANER
84HP 95TQ
CHROME? AS LITTLE AS POSSIBLE
AMSOIL
14/88
Old 06-18-2009, 09:08 PM   #5 (permalink)
dynarule's Avatar
dynarule is an unknown quantity at this point
there has been some cases that have cracked from trying to remove that plug.
dynarule is offline   Reply With Quote
Old 06-19-2009, 09:05 AM   #6 (permalink)
That plug is installed with red loctite if you must remove it ,it has to be heated up. On a warm engine there will be little if any oil in the sump,warm it up change oil ride....tom..
Old 06-19-2009, 06:14 PM   #7 (permalink)
Deeply Disturbed
gr8whyt's Avatar
gr8whyt is on a distinguished road
Unless the engine has a sumping problem, there's only gonna be a few ounces of oil in there. Your mixing that with around 100 oz of new oil. If your worried about the old and new oil not getting along, just shorten the first change interval to say maybe 1,000 miles. No worries.
-- gr8whyt
2004 FLSTCI - "White Owl"
gr8whyt is offline   Reply With Quote
Old 06-19-2009, 06:22 PM   #8 (permalink)
Faast Ed is an unknown quantity at this point
More so when reinstalling the plug. It is a tapered plug and it will crack your case when overtightening it. 14 ft lbs max, if I recall correctly.
Better off not messing with it.
Get your motor to full operating temp. Get your tools ready then again let it idle for a minute or so. You should have minimal oil left in the case to worry about.
Faast Ed is offline   Reply With Quote
Old 06-19-2009, 08:09 PM   #9 (permalink)
mooooving out!
route66paul's Avatar
Don't be anal, it isn't enough to matter.
43%er
Bi-polar and loving it!!
Bi-polar and hating it!!
95" w/ KB pistons (flattops)
HQ575 cams
Atwood's Road Warrior Heads
.030 head gasket
SuperTrapp Supermeg 2in1
"43" points cover
TRW rear mount
obligatory Baisley Spring
Just sayin..........
Old 06-19-2009, 08:20 PM   #10 (permalink)
I did pull the plug after I took a short ride. I let it drain at the same time as the oil pan. I did not measure what came out. That would be real anal, but I did feel better doing it. At $9.00 a quart I wanted to delute it as little as possible. I probably won't do it again though.
Old 06-19-2009, 09:04 PM   #11 (permalink)
Like I said earlier: don't overtighten that plug or you'll be replacing ALL the oil again (along with the rebuild needed when replacing your cases). At least you won't have to worry about the dilution anymore.
