06-13-2009, 10:36 AM
Why not to run synthetic oil, opinions
I have heard some say its bad for your bike, looking for opinions and proof "motor pics."
This should be iinteresting.
"Old EL Paso"
 2006 FLTRI 95"
Andrews 37g/SS, Quick Link rods, SS lifters, Cometic .030, SE Wires, SE 25*,no head work yet, SE 95" tops, rebored cylinders, SERT, SE breather, SE clutch spring, Aims VP83S, Bassani Road Rage, 880 Metzzlers, Barrnet cables, Wild Ones RG., Sony GT630UI & Hog Tunes. RC Cycles dyno 100/106
50mpg.
06-13-2009, 11:16 AM
FOG
I can't imagine any way that any synthetic or dino oil that meets spec is "bad for your bike." Makes no sense.
trooper113
NRA Endowment Member
AMA Member
06-13-2009, 11:50 AM
10000 posts on dino vs synthetic. Short version if someone gives you advice that synthetic oil will hurt your bike STOP listening to them. Even hd sells a synthetic blend. You can read for day's if you just use the "search function"
06-13-2009, 12:37 PM
I switched from dino 600 miles ago. I cant wait for the 5000 miles to be over so I can switch back.
My oil temp went up 20-25 degrees. This alone will cause me to switch back.
The tranny is quieter, so It can stay in there.
06-13-2009, 12:54 PM
No one told you that you have to wait. Change it now if it is so horrible.
Filter is still clean, so you can limit your loss by keeping your filter.
Myself, will stay with syn.
I find that people who run oil temp gauges tend to worry too much.
If your motor is too hot, it will tell you.
Too many false readings out there on many of these oil temp gauges, and too many other variables alter the temp readings.
06-13-2009, 01:00 PM
I can't imagine an engine running hotter from running synthetic oil. Makes no sense.
06-13-2009, 02:14 PM
FOG
While I won't argue with a guy who says his bike runs hotter with syn than with dino, I don't see how that's possible.
trooper113
AMA Member
06-13-2009, 02:28 PM
i think mine runs about the same the same temp, maybe a few degrees cooler
09 night train, big sucker 2, hooker dark side troublemakers , stage 1 map download, vance and hines fuel pak, autometer tach, saddlebags, and smoke out turn signal lense, and removed the mirrors. flat black paint job undecided on what to do next, i swear this thing handles better than my 98 sporty 1200
06-13-2009, 02:30 PM
could be that....the temp. is starting to rise all over this great country we live in. summer is here
07 ULTRA
S&S 106 CI
Big Boyz heads
D&D Fatcat
Hillside/Green A/C
SE 204
GARMIN 2610
3 GAL. AUX FUEL CELL
IBA# 31913
BBG
1566 MI 23 HR'S
Thomas Jefferson
06-13-2009, 03:34 PM
loath as I am to encourage yet another oil string
...Global Warming, eh?
Certified Geezer: 05 Road Glide
DoD #0472
DoD credo: "Live to Flame; Flame to Live"
06-13-2009, 03:44 PM
There has to be other factors involved. It's not the syn oil.
06-13-2009, 03:59 PM
0043--Licensed to Doof!
Your motor does NOT run hotter. It gives OFF more heat when running synthetic. THATS why it FEELS hotter. But in reality, your internal temps are cooler.
I Doof, therefore I am.
D.F.F.D
06-13-2009, 04:46 PM
Keep the rubber side down
Just curious. If your motor does get too hot, what will happen? I run Amsoil, so I don't have to worry about it, I hope. But I do live in Arizona...
04 E-Glide Standard
95" Big Bore
SE A/C
V&H Pro Pipe HS
06-13-2009, 05:06 PM
Noisier, weaker, sometimes more detonation.
Something you just feel about it. If it happens, you'll know.
Of course, as you said - you run Amsoil so it will never happen to you.
06-13-2009, 05:48 PM
They say the bearings will skate with that slick stuff
