06-05-2009, 10:33 AM
Torco V-series "SS" Syn 20W-50?
OK, I've read the many posts about Torco V-series oils touting their MPZ - aeration/foam reducing additive. But most of the Torco oil talk has been centered around their straight 50W or 60W petroleum based oils. I personally want to use the same type of engine oil through out the riding season which can include some pretty cool/cold temps, so I don't believe straight weight oil is the way to go - especially a petroleum based oil. I am also a big believer in using a quality synthetic in the engine, so who can give me feedback on Torco's V-series "SS" Synthetic 20W-50 oil which also uses the additive MPZ? Does their MPZ really cut down or eliminate foaming? Will this oil really reduce engine temps vs. competing 20W-50 synthetic oil?
SFTL-1
04' Deuce
95" w/HTCC 10.5:1
SE 257, HTCC Heads & Intake
Hooker Troublemaker Pipes
06-05-2009, 04:00 PM
I've been called abrasive
Our primary oil we use here is Torco's 20-50 "SS" synthetic & "TR" blended oils, we have never had any problems. Out here on the left coast heat is always an issue, the Torco oil's help dissipate the heat better than most. We have not seen any problems with foaming caused by the oil.
06-06-2009, 06:50 PM
20/50 V series works well in the spring and fall with the 50wt being good up to 85 or 90 degrees. If temps are over 90 then you can run the straight 60wt. My temps are cool, and I'm switching to 50wt on the next change. 60wt when I go to sturgis this summer.
Custom FXR Hotrod
(Build in Progress)
06-06-2009, 09:22 PM
Do you change your oil a 3rd time when temps fall back down into the 70's-80's and then once again when they drop below 70?
SFTL-1
04' Deuce
95" w/HTCC 10.5:1
06-06-2009, 10:01 PM
I'll run 20/50 when temps are low in the spring and fall like they are here in the West of the Rockies. Once their over 60 degrees on a regular basis (July & August) I'll run 50 weight. When running in temps over 90 degrees such as the 100+ temps in Sturgis, i'll run 60 weight. I change my oil to match temperature conditions and that helps protect my investment. Oil is cheap, high performance motors are not. Pretty simple equation.
Custom FXR Hotrod
(Build in Progress)
06-06-2009, 10:52 PM
I hear ya...my bike always gets fresh oil ,, lots of dollars in it.
My 1999 dyna
95 cu in
Se-flatops
Se-heads
Se-adjustable pushrods
S&S 570G cams
.030 cometic HG
Dtt ignition
100hp/102tq
06-08-2009, 10:14 AM
GasCan - Just so clear on this, based on where you're located, it sounds like you will be changing your engine oil 5x per riding season - 20W/50 > 50W > 60W > 50W > 20W-50???
SFTL-1
04' Deuce
95" w/HTCC 10.5:1
06-08-2009, 10:20 AM
Can you use the torco in the primary and tranny also like the synthetic S/E?
06-08-2009, 10:53 AM
The v-series "SS"synthetic has a JASO MA rating, so it's suitable for the primary, but I don't believe it would be your best bet in the transmission as there are other lubes (mainly gear oils) that will work better in the transmission (imo).
SFTL-1
04' Deuce
95" w/HTCC 10.5:1
06-08-2009, 12:52 PM
Moneygreen
If i'm not mistaken they make transmission & primary oil as well?????
Craig G.
06-08-2009, 04:44 PM
Torco has 100% synthetic primary oil (rated API GL-4) and SGO gear oil in different weights (rated GL-6 SAE 75w-90, SAE 75w-140 and SAE 250). We use the SGO 75w-90
06-08-2009, 10:42 PM
Moneygreen
On there website it calls it a synthetic blend??? And it doesn't advertise all the above weights!!!!!
Craig G.
06-08-2009, 10:52 PM
I think DB is referring to this: http://torcousa.com/products/product...a-cd0965cef88c
I'm sure you're looking at the v-series line for Harley & V-Twins?
SFTL-1
04' Deuce
95" w/HTCC 10.5:1
06-09-2009, 11:29 AM
Well said!
_______________
04 softail standard
Baisley-Axtell 117 - Baisley pro street heads - Baisley hybrid injection
Bob Wood TW-8 - Darkhorse crank - P.M. Hydraulic clutch
P.M. Villain wheels-rotors
Builder - hdryder
07-18-2009, 08:25 PM
Well I ran Torco for about 5000 miles and switched back to Redline Synthetic. Not only did the Redline drop the temp a bit, it's also quieter. Ran the coast to Cali and all I could get when it was time for a change was Redline and I'm happy to have switched back. Now have Redline in all three holes again.
Custom FXR Hotrod
(Build in Progress)
