Torco V-series "SS" Syn 20W-50? - Page 2 : V-Twin Forum: Harley Davidson Forums
Old 07-18-2009, 08:58 PM   #16 (permalink)
SFTL-1's Avatar
SFTL-1 wants to know Dino or Syn?
Originally Posted by FlyingGasCan View Post
Well I ran Torco for about 5000 miles and switched back to Redline Synthetic. Not only did the Redline drop the temp a bit, it's also quieter. Ran the coast to Cali and all I could get when it was time for a change was Redline and I'm happy to have switched back. Now have Redline in all three holes again.
Not to take anything away from Redline as I they have a good product, but I'm guessing you could have replaced your 5000 mile old Torco oil with fresh Torco oil and you would also have gotten slightly lower oil temps and reduced valvetrain noise?
SFTL-1
04' Deuce
95" w/HTCC 10.5:1
SE 257, HTCC Heads & Intake
Hooker Troublemaker Pipes
SFTL-1 is offline   Reply With Quote Quick reply to this message
Old 07-20-2009, 07:53 AM   #17 (permalink)
road king 100 wants to know Dino or Syn?
Torco 50 and 60w
I use 50w in winter(Dec, Jan, Feb) and 60w the rest of the year in my GMR 117. No problems. Temps over 115* here in the summer.
road king 100 is offline   Reply With Quote Quick reply to this message
Old 07-20-2009, 08:55 AM   #18 (permalink)
Moneygreen
arealinvestor's Avatar
Dude!!!! arizona doesn't have a winter!!!
T-Man gear crank set
Jagg 10 row oil cooler
K&P engineering oil filter
To much more to list!!!!!!
Old 07-20-2009, 04:09 PM   #19 (permalink)
DeluxeAl wants to know Dino or Syn?
Winter is a relative term....lol
DeluxeAl is offline   Reply With Quote Quick reply to this message
Old 07-20-2009, 06:50 PM   #20 (permalink)
Moneygreen
Originally Posted by SFTL-1 View Post
OK, I've read the many posts about Torco V-series oils touting their MPZ - aeration/foam reducing additive. But most of the Torco oil talk has been centered around their straight 50W or 60W petroleum based oils. I personally want to use the same type of engine oil through out the riding season which can include some pretty cool/cold temps, so I don't believe straight weight oil is the way to go - especially a petroleum based oil. I am also a big believer in using a quality synthetic in the engine, so who can give me feedback on Torco's V-series "SS" Synthetic 20W-50 oil which also uses the additive MPZ? Does their MPZ really cut down or eliminate foaming? Will this oil really reduce engine temps vs. competing 20W-50 synthetic oil?
The synthetic blend doesn't advertise on their site as having this MPZ additive???
Old 07-20-2009, 07:05 PM   #21 (permalink)
Moneygreen
I think DB is referring to this: http://torcousa.com/products/product...a-cd0965cef88c
I'm sure you're looking at the v-series line for Harley & V-Twins?
Yes I was!! Is that safe to use in V-twins??? It's advertised as a car product???
Old 07-21-2009, 09:44 AM   #22 (permalink)
SFTL-1's Avatar
It should be, but the oils labeled for V-Twin, Off-road, Racing etc typically have higher levels of Zinc & Phosphorus which are at lower levels in automobile use oils as they create havoc with catalytic converters.
SFTL-1
04' Deuce
95" w/HTCC 10.5:1
Old 07-21-2009, 09:48 AM   #23 (permalink)
Moneygreen
Don't know if i would trust car products in my $22,000 bike???
Old 07-21-2009, 10:01 AM   #24 (permalink)
SFTL-1's Avatar
As I understand it, MPZ is not a miracle chemical. It's simply a name Torco gave the chemical combination of Moly, Phosphorus & Zinc in the early 70's. I believe that most quality oils all use these chemicals to a certain level and it's the amount of these ingredients that separate their recommended usage for vehicles with catalytic converters vs. everything else.
SFTL-1
04' Deuce
95" w/HTCC 10.5:1
Old 07-21-2009, 10:45 AM   #25 (permalink)
DBChoppers's Avatar
DBChoppers wants to know Dino or Syn?
Here ya go
http://www.torcousa.com/products/pro...5-72fdf0e6c205
Diamond Bar Choppers
(909) 861-8833
DBChoppers is offline   Reply With Quote Quick reply to this message
Old 07-21-2009, 10:49 AM   #26 (permalink)
Moneygreen
Originally Posted by DBChoppers View Post
Hey DB, would you recommend Synthetic for a new Big Bore/big cubic inch build???During the break in period???
Old 07-21-2009, 11:14 AM   #27 (permalink)
Phat117 wants to know Dino or Syn?
Not DB but my answer is no Craig.
You're going to do several changes during the first 1 or 2000 miles.
At least I hope you are. Any good quality dino oil is good for break in and should seat the rings faster.
_______________
04 softail standard
Baisley-Axtell 117 - Baisley pro street heads - HPI 55
Bob Wood TW-9bg - Darkhorse crank - P.M. Hydraulic clutch/AIM VPC
P.M. Villain wheels-rotors/brakes-D&D Lowcat
Builder - hdryder
Phat117 is offline   Reply With Quote Quick reply to this message
Old 07-21-2009, 12:19 PM   #28 (permalink)
DBChoppers's Avatar
In short yes, many manufacturers use synthetic oil straight off the assembly line and a few use conventional oil for break in. In our experience syn. oil works perfectly fine with no problems what so ever with seating rings or bearing skate. The bottom line is that if you want to use synthetic oil for break in you can, if you don't want to then don't.
(GEEZ I wish I could type as fast as Steve at GMR)
(909) 861-8833
