Leslie Kay'sJardineProducts.comMotorcycle-CommunicationDan Vance RacingBub EnterprisesRRcycles.comCycleGear.comCustom Dynamics
Old 06-01-2009, 05:54 AM   #1 (permalink)
A21M's Avatar
A21M is on a distinguished road
Exclamation Oil leak -- oil cooler
Hi all,
I just got back from a 2000 mile trip and have a severe oil leak on a 2005 Ultra. Oil had been blowing back all over the bottom of the motorcycle and it was a mess when we got home from the trip. I ran out of oil on the trip and put a couple quarts in to get us home. It looks like most of the dripping is coming off the front end around the oil cooler. It is a Jagg oil cooler. I thought maybe the filter was loose so I put a new one one and made sure it was tight, then noticed the hoses from the filter to the cooler looked like they slipped a bit. I did reinsert them and made sure they were on and tightened the clamps. Took her for a ride and still have the leak, but not as bad. I am going to take off the oil cooler and see if that solves the problem. If not I will have to take it in for a look.
A couple questions...Has this happened to you with your oil cooler? Did you remove and fix the problem? Also, if this does not fix the problem by removing the oil coller, is there a way to pressure test the engine to find the leak?
Thanks in advance
Andy
God Bless, Ride Safe
"Grab life by the throttle and don't look back"
2005 Ultra Classic
Four simple words to say when you pass another rider
"God Bless the motorcyclist"
A21M is offline   Reply With Quote
Old 06-01-2009, 06:52 AM   #2 (permalink)
F$ck Google ads
ViennaHog's Avatar
Question from my end: Have you sent a 'thank you' for surviving the trip back home with an oil cooler spraying oil likely all the way down to you rear tire?
2008 Ultra dark blue pearl
BigBoyz ported street heads
103" SE FT
0.030 Cometic HG
Woods TW 6
V&H Monster Ovals
SE ventilator a/c
TTS
SE compensator
SE race clutch
VPC 92 T
Magura hydraulic clutch
BaggerBrace stabilizer
Full floater front discs
After Douglas Adams RIP
ViennaHog is offline   Reply With Quote
Old 06-19-2009, 12:27 AM   #3 (permalink)
Gino is on a distinguished road
I had a hose crack right on the clamp at the cooler return and I was lucky it left a nice puddle at the gas station before I took off again. I would've never noticed if I was rolling. I'm wondering if they're worth all the trouble and cost to begin with?
2003 Road King Classic - Vivid Black
Gino is offline   Reply With Quote
Old 06-19-2009, 08:11 AM   #4 (permalink)
Stashu11 is on a distinguished road
My dealer changed out the clamps to a different kind (not the screw on kind). I wasn't having a problem, but he saw it as a potential one. Maybe he's right?
Stashu11 is offline   Reply With Quote
Old 06-19-2009, 08:29 AM   #5 (permalink)
Moneygreen
arealinvestor is on a distinguished road
Damn I was thinking the same thing!!!Lucky mofo he was!!!!
Craig G.
