Dan Vance RacingCustom DynamicsDiamond Bar Choppers SportbikeTrackGear
Original Bike Spirits
Old 06-30-2008, 07:58 PM   #1 (permalink)
Cabo Wabo '06
namooz's Avatar
namooz is on a distinguished road
Oil, oil, on the floor-must I spill a little more?
Well, you would have been proud of me today-almost. For the umteenth time I changed my bike oil and nary spilt a drop. First time......Amazing, until I kicked out the jack and it rolled right into the oil container, and, you guessed it, spilt dirty oil on the floor. I swear the jack rolled in a controlled manner without skipping a beat on some kind of power of its own.
My oil changes are jinxed. I will never change oil in a vehicle without spilling it somewhere. Anymore, I like to think of it as a skill.
So, go ahead, spill that oil. I do.
05' Deluxe EFI/BC Pearl
Build, blueprint, & fine tune
95" KB domed pistons (10.3 to 10.6 dyn.comp.)
.030" commetic/.035" quench
HD cyl's .001" piston fit
06' modded heads
B Diamond high lift springs
perf valve job (Boyd's)
TW55 chain drive cams
S&S adj. pushrods
SE heavy clutch diaphram spring
Hi comp A Balls starter
Rivera 10/84 Ring gear
polished TB/manifold
Doherty w/Power Vents
Pro Pipe HS header w/Cycle Shack Rocket tip muff.
PCIII & Dyno
Jagg oil cooler
93HP/98TQ
namooz is offline   Reply With Quote
Old 06-30-2008, 08:11 PM   #2 (permalink)
My buddy didn't realize he forgot to put the drain plug back in his car until he was three quarts in. Nice new coating of oil for his driveway.
'04 Brilliant Silver FLHRSI
Old 06-30-2008, 11:05 PM   #3 (permalink)
Ride like the wind
doc ock's Avatar
I remember as a kid my dad did the same thing but I think all 5 quarts hit the driveway before he realized what happend, man he was pissed.
04 FLHTI
REDSHIFT TC557 GEAR DRIVE CAM
ZIPPERS THUNDERMAX ECM
V&H TRUE DUALS
KHROME WERKS HP PLUS 100
SE AIR CLEANER
84HP 95TQ
CHROME? AS LITTLE AS POSSIBLE
AMSOIL
14/88
Old 07-01-2008, 08:18 PM   #4 (permalink)
Phemus
steveusmc's Avatar
steveusmc is on a distinguished road
Last year my son-in-law was in my driveway adding M1 syn to his truck. I was just pulling his chain when I asked him if he installed the plug...and he responded...."Oh Sh*t!!". I told him to try not to do that on the C-130 gunship engines he works on.....the pilots would not appreciate it.
About the only oil I spill when I change the oils in my bike is the brand new bottle I knock over after I wet the seal on the filter...and don't screw the top back on. Mistake....
steveusmc is offline   Reply With Quote
Old 07-27-2008, 12:01 PM   #5 (permalink)
I've also given up. Just when you think you've got it under control, something will make a mess. The plastic sheet goes on the floor now before the drain plugs come out.
Ron
Old 07-27-2008, 12:40 PM   #6 (permalink)
Brother's Keepers MC
Cap'n Dave's Avatar
Cap'n Dave is on a distinguished road
pesticide/herbicide
seems to me that when i spill a little oil, thats one less bottle of round-up or ant poison i have to buy. Just kidding, for the most part
"Life's a B!TCH. If it were a WH@RE, it'd be EASY!"
2008 FLHX - White / Gold Pearl
S.E. Heavy Breather
S.E.R.T.
Klock Werks DoubleBack Headers
Tailgunner chrome Gunships
Cap'n Dave is offline   Reply With Quote
Old 08-05-2008, 03:04 AM   #7 (permalink)
Winter SUCKS!
harleymike77's Avatar
harleymike77 is on a distinguished road
Ron
That's actually a pretty good idea! Thanks rbabos, I'll give that one a try...........
2009 Street Gilde - Fully customized
Yes, it has a 200 mm rear tire
harleymike77 is offline   Reply With Quote
Old 08-05-2008, 03:08 PM   #8 (permalink)
bradnailer is on a distinguished road
My Dad used to work on drilling rigs. He said they told a worm hand to go change the oil in the tool pusher's car. The guy did but the car locked up on the way back to town. Turns out, he drained the transmission then filled the crankcase with more oil.
bradnailer is offline   Reply With Quote
