ATF in primary : V-Twin Forum: Harley Davidson Forums
Old 08-16-2007, 08:54 PM   #1 (permalink)
led scooter wants to know Dino or Syn?
ATF in primary
I have just serviced my primary and used M1 ATF synth type V due to the positive info on this website concerning ATF in primary. Question is...does using ATF cause any long term negative effects? Is it compatible with the seals, gaskets, etc? Has anyone had any trouble due to using ATF?
I am really pleased with the way my softail shifts, but I don't want to cause any damage down the road (no pun intended). I am hoping you will all chime in and re-assure me that it is all good....
led scooter is offline   Reply With Quote Quick reply to this message
Old 08-18-2007, 09:26 PM   #2 (permalink)
This isn't very reassuring...maybe I should switch back to motor oil for my primary??
Old 08-18-2007, 09:36 PM   #3 (permalink)
Premium octane member
TXCHOP's Avatar
Sorry, missed your post initially....
Been running ATF in mine for a while...What side effects are you worried about..
Charging system, clutch wont have any long term effects. the only problem i have ran into atf is it makes my rivera proclutch a tiny bit louder and if you primary leaks already, the atf is thinner and will leak...But if you have no leaks, you will be good to go.
S&S T124
Old 08-19-2007, 09:23 AM   #4 (permalink)
ViennaHog wants to know Dino or Syn?
Been running ATF Type F in my 107 primary for some time now. Better clutch separation when cold and easier to find neutral due to reduced drag of the friction plates. And as TX said, if your primary seals are on their way out, they will go quickly with ATF.
ViennaHog is offline   Reply With Quote Quick reply to this message
Old 09-18-2007, 08:23 AM   #5 (permalink)
Life is short pray hard!
Starbound wants to know Dino or Syn?
If a guy was going to run ATF in the primary what type of fluid should you run? A guy I know runs B&M Trickshift in his primary and really likes it. I have a couple of bottles of Amsoil Universal ATF that I bought for my car and never used, is this the right stuff?
Starbound is offline   Reply With Quote Quick reply to this message
Old 09-21-2007, 08:11 PM   #6 (permalink)
georgedouglas's Avatar
georgedouglas wants to know Dino or Syn?
The Amsoil ATF will work fine in your primary.
Buying Amsoil from us, your forum sponsor, helps to support this site. Orders are shipped ASAP from our nearest US or Canadian warehouse.
George@OilHelp.com or 1-800-887-6698 or http://oilhelp.com/motorcycles
Old 09-22-2007, 05:59 AM   #7 (permalink)
Average Dude
YankeeBob's Avatar
YankeeBob is reading this now saying WTF is this?
I have had M1 synthetic ATF in my primary for about 2000 miles now. No problems. I like it. Clunking is gone, shifts smoother, neutral is easier to find, etc....
Deut. 23:12-13
YankeeBob is offline   Reply With Quote Quick reply to this message
Old 09-24-2007, 12:42 AM   #8 (permalink)
Joel's Avatar
Joel wants to know Dino or Syn?
I just took out Redlibe ATF from the primary. I will never put that in again. The bike had a bad knock when it was cold. I switched to another oil and the knock went away.
Joel is offline   Reply With Quote Quick reply to this message
Old 09-24-2007, 08:59 PM   #9 (permalink)
HDSG wants to know Dino or Syn?
Smile
Should have used AMSOIL................just kidding............
I think the noise had nothing to do with the oil............really..........
HDSG is offline   Reply With Quote Quick reply to this message
Old 09-24-2007, 09:04 PM   #10 (permalink)
PR3VS56's Avatar
PR3VS56 wants to know Dino or Syn?
Right now I'm running an off the shelf Dextron (I think it was Castrol brand) per RiveraPrimo instructions. Seems fine. What would I notice by switching to, let's say the Amsoil synthetic ATF?
'09 FLTRI, Vivid Black, ABS.
106 cid, 123tq/113hp
'05 FLTRI, totaled 10/17/08.
105tq/107hp
'00 FLHRCI, sold.
Proverbs 3:5-6
Fruit of the Spirit
PR3VS56 is offline   Reply With Quote Quick reply to this message
Old 09-25-2007, 07:45 AM   #11 (permalink)
You probably wouldn't notice anything different unless you were riding in very cold temperatures. Synthetics generally shine in low and hot temperatures over conventional oils.
Old 09-25-2007, 07:50 AM   #12 (permalink)
PR3VS56's Avatar
Thanks.....
105tq/107hp
'00 FLHRCI, sold.
Proverbs 3:5-6
Fruit of the Spirit
Old 09-26-2007, 05:40 AM   #13 (permalink)
Atf
I'll chime in with this.
Bandit Machine Works, (John Magee,owner) reccomends atf with their clutches.(link from our site) Have known of folks using it back in the late 80's.
We have never witnessed any problems with it.
Old 09-27-2007, 12:27 AM   #14 (permalink)
muleskinner's Avatar
muleskinner wants to know Dino or Syn?
Why use ATF in the first place? HD spends big bucks for engineers to do R&D and we want to change from what they recommend to ATF. Why?
muleskinner is offline   Reply With Quote Quick reply to this message
Old 09-27-2007, 01:12 AM   #15 (permalink)
You mean the same R&D guys that provided us with twisted cranks, failed crank bearings, the clatter cruise drive gear box and some other goodies?
