05-17-2007, 06:07 AM
What is H-D Primary Oil ?
Just went to the stealer and got my 7$ bottle of Primary oil,and my $3.50 primary plug and $11 gaskets what a rip.Why dont they have what weight the oil is on the bottle?Im running Mobil one in the other 2 holes.Any good suggestions for the primary,I here scyn oil is not good to run in primary may reduce clutch life.Thanks for the input
05-17-2007, 06:17 AM
You guessed it
I use Mobil One V Twin for the primary. Works great!
05-17-2007, 06:39 AM
10W-40 is the correct weight oil. Some folks are advocating ATF but I've yet to try it. I think there's a thread about it somewhere.
Those of you who think you know everything are beginning to piss off those of us who do.
05-17-2007, 11:29 AM
Infidel
George Douglas the Amsoil rep and site sponsor had it analyzed and I quote: "What I was told by the lab at Amsoil on the formula+ product is that it is basically a 50 weight mineral oil with some anti-wear and a small amount of extreme pressure additives in it, as well as some of the other basic additives like anti-foaming and rust inhibitors and etc. Looks like a very cheap product to manufacture."
John Levanger
05-17-2007, 12:57 PM
All the fancy additives don't do you any good in the primary and could hurt clutch performance. I would stick with what HD says or a basic oil. Olive oil could lube the chain and keep the clutch wet.
43%er
Bi-polar and loving it!!
Bi-polar and hating it!!
95" w/ KB pistons (flattops)
HQ575 cams
Atwood's Road Warrior Heads
HPI bored throttle body
.030 head gasket
SuperTrapp Supermeg 2in1
"43" points cover
TRW rear mount
obligatory Baisley Spring
Just sayin..........
05-17-2007, 02:23 PM
primary oil
Rivera Pro Clutch states that ATF is the only recommended oil in the primary when using there clutch.
I have the Pro Clutch and ATF is what I use.
05-18-2007, 01:33 AM
not sober all the time
Yeah but don't tell Popeye.
05-25-2007, 11:44 PM
Same here, less volume though than what HD calls for, per the Rivera instructions.
'06 Deuce, GMR 98" kit, 10.8:1 CR, 615/585 cams, S&S Gear Drive, GMR 1.67 roller rockers & lifters, R&R Cast Heads, CP Pistons, HP Inc. 55 mmTB and Intake, Feuling oil pump, Baisley Spring, Rivera Pro clutch, 3:37's, D&D Fatcat, SERT.
114.06 TQ
125.70 HP
Never pet a burning dog..........
03-11-2008, 06:23 PM
yes but what kind of atf? ford chevy etc cant remember letters
03-11-2008, 06:46 PM
The ATFs I've used are B&M Trickshift and Amsoil Super Shift.
Both worked quite well but the Amsoil has been superb, in my opinion.
'04 Brilliant Silver FLHRSI
03-11-2008, 07:16 PM
Dues are Paid
Use this...
http://www.mobiloil.com/USA-English/...4T_10W-40.aspx
""Mobil 1 Racing 4T 10W-40 is designed for sport bikes. Most of these bikes have multi-cylinder/multi-valve engines and use a common sump, which means the engine oil lubricates the engine, transmission and wet clutch. So unlike Mobil 1 for cars, Mobil 1 Racing 4T 10W-40 has no friction modifiers, which could lead to clutch slippage.""
I am a mobil 1 guy also...
2005 Deluxe
2010 Ultra
2005 Deluxe
S&S 106" Crank, S&S Pistons, 10:25/1 Ported Heads, Comp. Releases,
S&S 585G, S&S Roller Tappets, SE Roller Rockers, SE Adj. PushRods, Feuling Oil Pump,
LMR-02 spring, SE Clutch Spring, Easy Pull Ramp, PCIII, V&H Big Shot Staggered
106hp/122tq
___________________________
"A life spent making mistakes is not only more honorable but more useful than a life spent doing nothing."
George Bernard Shaw
03-12-2008, 06:43 AM
From the Rivera instructions, "fill the chain case with Dextron III ATF to the bottom of the ring gear."
03-12-2008, 08:40 AM
Retired Navy - MCPO
ATF type F will also work fine on standard clutch setups.
Ed Y
2002 FLTRI
I yam what I yam.
03-12-2008, 04:10 PM
ok thanks a lot guys -
03-12-2008, 07:57 PM
Good point Ed. I've used type F on the stock clutch and the Rivera. I couldn't say there is much difference from Dextron III.
| Sponsored Links |
