» Buyers Guides |
05-31-2005, 12:50 AM
Hellbound Train
Informative Links
As suggested by Snowman, this thread is for anyone to post link's that contain worthwhile information, MSDS Sheets, oil comparrisons, additive packages, oil analysis, whatever.
It is for information only, any inappropriate postings will be removed.
Chuck Soday
GO FAST
'03 FXSTBI 103" Stroker
112 hp -- 121 tq
100% S.E.
My V Twin Gallery
06-01-2005, 01:47 AM
Doing time, behind bars!
This page gives reasons why you can run a diesel rated oil in a motorcycle; I've not heard that it is neccessary to be rated as such before you can use it in a motorcycle however, if you find yourself in a situation like me (FREE oil at work) then you may find this information much more interesting
http://www.rotella.com/qa/answerresult.php?rowid=81
This gives the current API oil ratings
http://api-ep.api.org/filelibrary/Guidechart2002.pdf
06-02-2005, 02:36 AM
This is the best comparitive study I've found that relates specifically to harley davidson motorcycles and synthetic oils.
http://www.quickthrottlemag.com/article_syn.htm
07-16-2005, 10:57 AM
Originally Posted by Seahag
thanks for the link. best reading yet. guess i'll be savin about $4/quart
for the oil tank anyway. still be high priced primary and tranny.
todd
00' roadking
07-22-2005, 08:30 AM
Here's a couple of links that I find helpful in my line of work, I am the PM Customer Support Agreement contact, as well as new technology contact, for the Cat dealer down here.
http://www.lngpublishing.com/ (has an on line mag that has at least one good article a month in it on lubes, filters, base oil stock, greases, etc.)
http://www.cat.com/cda/servlet/cat.v...earchField=oil (links to lots of info on how to take a good oil analysis, etc.)
http://www.oilanalysis.com/dictionary/default.asp (oil analysis dictionary)
07-22-2005, 09:21 AM
Bitog
How did we go this long without putting this site in here?
BOB IS THE OIL GUY
Reason: format font
11-02-2005, 03:58 PM
Ride like the wind
Mobil users and Wal-Mart
On this sit there are a bunch of us who use Mobil in our rides, myself included. About 80% say they buy at Wal-mart because there can save a couple bucks. Well lets start saving our towns.
http://walmartwatch.com/ Information on how Wal-Mart really does buisness.
By the way I try to avoid this chain at all cost. I switched over to Amsoil. But it by the case and don't worry about running out.
03-12-2006, 10:52 PM
Here is a link with some rather technical info on lubrication and IC engines. Not all the papers deal with oil. Warning--they are technical.
http://www.iantaylor.org.uk/papers.htm
_______________________________________
DOH! NUTTS! Is there nothing they can't do?
04-04-2006, 03:22 PM
When extreme overheating situations exist, oxidation is rampant. The only cure for oxidation is changing the oil. Extreme heat indicates the need to change your oil more frequently.
Your fossil oil's effectiveness in lubricating drops off once its temperature increases beyond 250" F.
Oil Oxidation Rate Chart
When observing the accompanying oxidation rate chart, it will become readily apparent that heat is the enemy and must be controlled. With heat comes oxidation of the oil and the only cure for this is to change the oil. When extreme overheating situations caused by improper tuning or a brutally hot summer day exist, oxidation is rampant, so change your oil more frequently.
05-13-2006, 03:15 PM
http://neptune.spacebears.com/cars/stories/mobil1.html
Mobil 1 test and analysis I found interesting. Of particular interest to me is this statement:
"Engine wear actually decreases as oil ages. This has also been substantiated in testing conducted by Ford Motor Co. and ConocoPhillips, and reported in SAE Technical Paper 2003-01-3119. What this means is that compulsive oil changers are actually causing more engine wear than the people who let their engine's oil get some age on it."
10-26-2006, 09:32 PM
Used oil
Well i believe that oil gets more slippery when itīs well used, but even if it would decrease wear the oil would get contaminated at the same time by gasoline and other substances.
The reason for that oil gets more slippery and therefore decrease wear would be because the oil molecules breaks in smaller molecules after a while in use am i right?
But in real world conditions gasoline and other harmful stuff would mess things up anyhow.
So itīs a good thing to change oil now and then.
I donīt know how many times iīve encountered trouble with ***-bikes at my old job with a lot of gas in the oil. And gasoline isnīt that good as a lubricant.
10-29-2006, 10:23 AM
http://www.amsoil.com/lit/g2156.pdf
This is a "White Paper" I found very informative testing the different synthetic motorcycle oils. Being Syn3 is now $10.00/qt. and is associated with Venezuela, it's off my list. It looks like Mobil 1 v-twin and Amsoil rated the highest overall. Mobil is less expensive and therefore gets my nod. I'm going with Mobil 20w50 V-Twin in the crankcase, Mobil 75w90 gear lube in the tranny and staying with H-D Primary lube in the primary. If nothing, else I'll enjoy the savings over Amsoil and Syn3...about $2.00/qt.
11-16-2006, 05:41 AM
Just when you thought you'd read everything
This article is the best I've ever read for explaining oil formulation and certifications. It is worded and explained for the 'layman' instead of for industry insiders....very informative.
http://motorcycleinfo.calsci.com/Oils1.html
05-31-2007, 10:16 AM
Comparative Viscosity Chart, crankcase vs. gear oil
I see that we already hit Bob is the Oil Guy, but attached is a chart from BITOG showing Viscosity Classifications (i.e. why is 10W-40 roughly the same viscosity as 75W-90?) and here is a string discussing the accuracy of such charts.
