» Buyers Guides |
07-31-2008, 10:06 PM
75/90 or 75/140, which is better for an 88 Trans?????????
I have been using Amsoil 75/90 Severe Gear in my trans. I see that many are using the heavier 75/140, is the extra weight needed? Will the trans do better? Thanks for any and all replies in advance.
07-31-2008, 10:17 PM
Doof Toll Pimp
I run Mobil 1 75/140 in the summer (but I do put a lot of miles on in the summer) and
run 75/90 during the winter, fewer miles but ride it non the less..
have fun choosing..
To be old and wise,
Here's to old and stupid....
Orthopedic Motto
DooF'S Rule
04 FLTRI
95 Cubes
SE Hi-Comp Pistons
S&S .570 Gear Drive Cams
S&S Hi-Lift Valve Springs
Timken Conversion
Ported Heads
Gerolamy Dual Throttle Body
V&H True Dual Headers
V&H Python 3 Slip-on Mufflers
Daytona Twin-Tec III Ignitions System
Feuling Oil Pump/Cam Plate
07-31-2008, 10:45 PM
have fun choosing..
I think I should be doing the same. I am due to change all three fluids and I will go with the 75/140, it has been warm here and will continue to be for a while yet. Thanks.
07-31-2008, 10:52 PM
Doof Toll Pimp
stick to the synthetic.. I think that it performs far better than the dyno oils....
To be old and wise,
Orthopedic Motto
DooF'S Rule
04 FLTRI
95 Cubes
SE Hi-Comp Pistons
Timken Conversion
Ported Heads
07-31-2008, 10:58 PM
Absolutely.................Amsoil...........
07-31-2008, 11:22 PM
Since you're going with Amsoil, you may want to try their Severe Gear 75W-110 and use it year round...
SFTL-1
04' Deuce
95" w/HTCC 10.5:1
SE 257, HTCC Heads & Intake
V&H BR 2-1
Baisley Spring, Mobil-1 Oils & K&N Filters
07-31-2008, 11:25 PM
I'm using the Amsoil 74/140 Severe and am really happy.
My indy said the only reason to run the 75/90 instead is to squeak out a couple of more miles per tank. It's been really hot here and I ride a lot and get stuck in traffic time to time (DC) so I like the extra viscosity in the heat.
Lead, follow, or get out of the way I'm coming through!!
08-01-2008, 05:41 AM
semi-retired
or
75-110,split the difference.
I can't means I won't!
08-01-2008, 07:37 AM
Run the 75w-140.
It gives us the added film strength and does not affect the gas mileage. The 140 in a Syn is a whole different animal than a dino 140......
Use it with confidence.
2007 Softail Heritage Classic
SERT on 96 CI Engine, 12.8:1 Air/Fuel Ratio
SE Air Intake
Baffles Punched Out of Original Pipes - Wow, Super Deep Sound & Bark.
Lots of extra Chrome, always adding more
Averaging 600 miles a week
08-01-2008, 09:45 AM
Originally Posted by Pitch
Run the 75w-140.
Thank you for the input, I will be able to make a good decision.
08-03-2008, 12:37 AM
Ride like the wind
I run 75w-140 year round and won't need to change it for about 20,000 miles.
04 FLHTI
REDSHIFT TC557 GEAR DRIVE CAM
ZIPPERS THUNDERMAX ECM
V&H TRUE DUALS
KHROME WERKS HP PLUS 100
SE AIR CLEANER
84HP 95TQ
CHROME? AS LITTLE AS POSSIBLE
AMSOIL
88
There is one in every crowd and I'm am that one.
" Too Much Dishonesty and Bullshit Out There"
08-03-2008, 01:43 AM
 Same here.
04 GLIDE
95" 10.5 -1 S&S
TC-2G cams
RB Racing LSR 2 into 1
Ness Big Sucker
08-03-2008, 03:47 PM
Guys run what ever makes you more comfortable as you can not hurt your tranny using any of the combinations described in this thread. I have tested the 20w 50 Amsoil and their 75w 90 and each at 5,000 miles had the same exact wear characteristics or should I say no wear. I personally have not tried the 75w 110 yet, but would have no reservations using it.
george
08-03-2008, 10:55 PM
Site Sponsor
We run 75/90 PX3 Synthetic Gear oil ON STEROIDS!!!!!!!!!!!!
Sumax... Sponser
08-11-2008, 03:17 PM
I run amsoil 74-140 the most.
Sumax i hope that oil is better than your fenders for narrow glides , twisted junk and terrible custumer service.
