Pro PadBikeBanditArnottAirRideRosa's CycleEagleRiderWheeldock.comSpringfield ArmoryKomodoGear.comKewlMetal.comStoneyStraps.comProCharger.comCheapCycleParts.com
Go Back   V-Twin Forum : Harley Davidson Motorcycle Forums > V-Twin Performance Forums > Engine Oils and Lubrication Forum
BikeBandit
Old 07-04-2008, 08:10 AM   #1 (permalink)
IronBucket
Colonel Sanders's Avatar
Colonel Sanders is on a distinguished road
Thumbs up Torco engine and tranny fluid is installed
Went with 60w (I'll swap to 50w for winter) Torco (that's a non-synthetic) in the engine and 75w/140 in the gearbox per GMR's recommendation. I was running conventional HD 20w-50 in the engine before (this was during break-in of the new build) and Syn3 in the tranny (I didn't like the way it shifted with Syn3, BTW.) I also put some Trick Shift in the primary which is basically an F-type automatic transmission fluid.
Why the straight weight Torco? Firstly, because it has MPZ which is some really cool magic stuff that does good, wonderful, and fantastic things to your engine! The other reason is that in R&R's testing it controlled aeration and foaming in very impressive fashion. Because of this, R&R, Hillside, and GMR all swear by the stuff and that's plenty good enough for me.
I only put about 60 straight miles on it yesterday but I can tell one good thing already....It runs COOLER! Now I need to put more miles on it in different types of riding to draw firm conclusions but I can tell you that it's definitely running *AT LEAST* 10 degrees cooler than before, almost certainly 15 degrees cooler, and most likely more like 20 degrees cooler. Before it would run about 245-250 in the heat like yesterday (94 degrees and humid out) but yesterday it ran 225-230. Very nice! No need for an oil cooler with this stuff.
Keep in mind that this is a 137 HP 124" at 10.8:1 CR with no oil cooler that lives in the deep southeast. You wouldn't expect it to run any cooler than it does. In fact, I was quite ok with it running up to 260 degrees before but hey, cooler is better.
The Trick Shift really didn't seem to change anything with the clutch operation. I didn't do any WOT gear changes but parking lot maneuvering and normal starts seemed much the same as before, which is fine. I'd expected the clutch to feel more abrupt on engagement than before but it didn't, so that was nice.
Where did I get Torco? I just made a phone call to GMR Performance and Steve took care of the rest. Only took about 4-5 days to receive it. GMR is in Arizona and I'm in Alabama so that's pretty quick, IMO.
I'll try to update this thread as the miles pile on.
'01 Deuce
GMR 124"
4.125" x 4.625"
CV51 carb/intake/AC
R&R Stage IV heads
10.8:1 CR
JE -10cc pistons
S&S 640 cams
Axtell cylinders
JIMS/Darkhorse crank
Rivera Pro Clutch
DTT ignition
Hooker Troublemaker pipes
Assembly and tuning by Michael@Montgomery (AL) H-D
137/134 STD 134/130 SAE
Colonel Sanders is offline   Reply With Quote
Old 07-07-2008, 12:33 PM   #2 (permalink)
tolobill
hi, this question is probably for steve or scott maybe you know. i have a 98in roadking and am in georgia, is the torco 60wt motors that are bigger than mine or ant thing where it gets hot. my temps run 215 to 230 thanks.
tolobill is offline   Reply With Quote
Old 07-07-2008, 01:27 PM   #3 (permalink)
IronBucket
Maybe one of the big dogs can chime in for you but I would think that if it's good enough for a 124" that it would be more than adequate for a 98".
Old 07-07-2008, 02:19 PM   #4 (permalink)
DADAWG's Avatar
DADAWG is on a distinguished road
i would be curious how it compared in the same bike with redline 20-60 or amsoil 20-50 ?
DADAWG is online now   Reply With Quote
Old 07-14-2008, 05:37 PM   #5 (permalink)
I have an addiction.....
dennish's Avatar
dennish is on a distinguished road
Is the Torco 60W regular automotive oil or diesel or air cooled oil? thanks.
dennish is offline   Reply With Quote
Old 07-15-2008, 01:21 AM   #6 (permalink)
IronBucket
It's "Harley and V-twin" oil. It's called V-series "ST". Take a look...
http://www.torcoracingoils.com/produ...2-415ed079de42
Old 07-15-2008, 11:00 AM   #7 (permalink)
dennish's Avatar
Thanks Colonel, looks like there is a dealer in town.
Old 07-15-2008, 11:19 AM   #8 (permalink)
IronBucket
There were two dealers fairly local to me too but they didn't carry the V-series (carried mainly the stuff for dirt bikes, watercraft, and other water cooled engines) oil nor would they order it (said the shipping would be more than the product...which is complete BS as I've already proven.) So, I ordered it from GMR. When you buy it a case at a time (enough for 4 changes) the shipping isn't bad at all.
'01 Deuce
GMR 124"
4.125" x 4.625"
CV51 carb/intake/AC
R&R Stage IV heads
10.8:1 CR
JE -10cc pistons
S&S 640 cams
Axtell cylinders
Rivera Pro Clutch
DTT ignition
Old 07-15-2008, 05:32 PM   #9 (permalink)
dennish's Avatar
Well my local place is the same type, a dirt bike, ATV shop but he said he would order it, in fact he was getting ready to place an order today. He said it should be here tomorrow, so we will see. I ordered only 6 qts.
Old 07-15-2008, 08:29 PM   #10 (permalink)
GHOSTRIDER LIFE MEMBER
1711tab's Avatar
1711tab is on a distinguished road
I think you'll like the results...
"KING OF CUBES" - HYPERFORMANCE & R&R CYCLES R&D MONSTER 131" BUILD
INNOVATORS NOT IMITATORS
"YOU CAN'T SOLVE PROBLEMS BY USING THE SAME KIND OF THINKING YOU USED WHEN YOU CREATED THEM"
1711tab is offline   Reply With Quote
Old 07-18-2008, 08:57 PM   #11 (permalink)
bmaker is on a distinguished road
I am getting ready to make the switch to Torco for a trial as well. Just like many on this forum, trying to calm down the noisy gremlins in my TC. I notice they also offer a 20W50 as well. I am by no means an oil expert but when the motor reaches normal operating temps, is there any difference in a 20W50 and straght 50W?
bmaker is offline   Reply With Quote
Old 07-19-2008, 01:23 AM   #12 (permalink)
Junk Yard Dog
dscott is on a distinguished road
I was having heating problems on my 02 Soft Tail so I started doing some research. I finnaly found a GREAT Indy in Hillside and Scott set me on my way. I added Turco 50W in the engine, red line in the trans and primary and installed a Jagg oil cooler. I have to say I am very pleased with all the changes Scott at Hillside suggested. The Turco has made a huge difference in the engine, runs much quieter, dropped about 30 degress in oil temp and trans shifts much smoother also finding nuetral with 1 click of the foot.
I ride in the Texas heat on a daily basis so heat was a big concern for me.
I was running HD syn3 and once I changed and experienced the difference I will never go back.
Turco for me all the way in engine and Redline in trans and primary.
A big THANKS to Scott at Hillside for being honest and helping me out. Cost a little more with shipping but well worth it !!!
Live Long, Ride Hard, Love Often
02 Soft Tail Heritage Cherry Black
V&H shorties
Hyper Charger Air Cleaner
PCIII
Andrews 26 Cams
Heads by Hillside =9.5-1 comp, 1.90 Intake Valves
TB ported to 46mm
SE Adjustable Push Rods
Chrome, Chrome and more Chrome
dscott is offline   Reply With Quote
Old 08-11-2008, 10:34 AM   #13 (permalink)
1711tab's Avatar
Randy (HYPERFORMANCE) and Reggie (R&R CYCLES) both recommend it in all V-Twin Builds... No matter what the inches are...
Old 08-11-2008, 02:02 PM   #14 (permalink)
tolobill
ok, well the only question left is should i use the 50wt or the 60wt thanks.
Old 08-22-2008, 01:30 PM   #15 (permalink)
What's the speed of dark?
FLSTCI124"'s Avatar
FLSTCI124" is on a distinguished road
Reading the Torco website, they state that the 50 & 60 wt oils are for pre-84 motors?
I'm leaning towards giving the 60wt a try and see how much difference there is in engine temp.
Currently using Mobil 1 synth and there always seems to be noise coming from my top end.
S&S 124" TC-B
Zippers 54mm TB
Branch - O'Keefe Headwork
S&S .640 cams
S&S Gear Drive
Fueling Super Pump
Fueling Lifters
DTT TCFI IID
DTT 6.0 Injectors
RB Racing LSR Pro Stock 2-1
FLSTCI124" is offline   Reply With Quote
