Dan Vance RacingAmerican Side Road Cycle
BikeBanditCycleGear.comSportbikeTrackGearMotorcycle.com Classifieds!Motorcycle.comCustom Dynamics
Old 08-27-2006, 11:02 PM   #1 (permalink)
Salty is on a distinguished road
Before you upgrade your headlight bulb...
Was pretty happy with intial running of a Candlepower Rally Premium 100/55W P43t-38 blue xenon bulb purchased from dealer. The high beam was great. After 3 months and about 7000 miles the low beam burned out - so I bought another thinking it was a fluke. Second bulb lasted just under 3 months and just over 8000 miles. Is this a common occurance? Original bulb was good for 22K and is still good as I used it to replace the last two that burned out. Thoughts, comments, recomendations on a bulb for 100 watt high beam that will last more than 3 months?
Scott LaShier
Salty is offline   Reply With Quote
Old 08-28-2006, 03:43 AM   #2 (permalink)
killer sperm
Milehog's Avatar
Milehog is on a distinguished road
Any time you run a hot bulb you need to carry a spare. A bulb with an 80 watt hi-beam will last a lot longer than the 100 watt bulb.
Milehog is offline   Reply With Quote
Old 08-28-2006, 02:46 PM   #3 (permalink)
Low Beam?
Good info on lower watt lasting longer but does that reference the high beam or the low beam as that is the one I had burn out.
Old 08-28-2006, 03:27 PM   #4 (permalink)
Fire4Effect's Avatar
Fire4Effect is on a distinguished road
I burned out 3 bulbs (low beams) in 6 months this year before I found that one of the 3 terminals on the female socket was "sloppy." The male terminal was kinda vibrating around in there and you wouldn't see the light flickering or anything, but it was sending over-current into the bulb that would eventually burn it out WAY too soon. On the 3rd bulb I squeezed down the connecters first so that the bulb made a very solid contact when slid into the socket. Problem gone...
Fire4Effect - Eatin one bug at a time...
2002 FXSTD - 106" 10 -1 comp / S&S heads / Mikuni HSR-42 Carb / 570G cams / DTT Ign / Feuling oil pump / V&H longs
Fire4Effect is offline   Reply With Quote
Old 08-28-2006, 08:28 PM   #5 (permalink)
2005 Road King Classic
bbrowncods's Avatar
bbrowncods is on a distinguished road
Great point! you could also use dielectric grease to aid the connection.
05 Road King Classic - Sierra red pearl/Bassani Power Curve and Megaphones w/torque baffles/98" RevPerf BB/37g cam's/Stock 99B lifters/TTS/Stage 2 CNC'd heads by R&R(GMR) 9.7 CR/50mm Gerolamy Dual Throttle and filter/500cc injectors/Super Premium Oil Cooler/SE Clutch spring w/Easy-pull ramp and a bunch of this and that!
bbrowncods is offline   Reply With Quote
