Sounds like a bad wire to the ignition or coil.
Might check the white and pink wires to the coil posts, have to pull the coil cover off to see them. Also, the wires to the coil run down the frame behind the coil and can rub on the coil bracket, make sure you do not have any damage to them.
Also, check the plug from the pickup inside the cam cover. The plug should be down by your oil pump. Follow the wires coming out of the cam cover. Make sure it is not corroded or loose.
A fellow member here did have an itermintent regulator problem. Turned out to be loose wires in the regulator where they went into the regulator.
The voltage at the battery should be higher than 13.5 volts, maybe around 14 volts at 3k rpm.
Note, my "93 Heritage ran with a bad stator with a battery voltage as low as 8 volts. (no Lights)
Next would be a bad ground somewhere in the ignition circuit.
Good luck.
Ride Hard but Ride Safe.
