Wrong year, will it work : V-Twin Forum: Harley Davidson Forums
Old 08-08-2005, 11:16 AM   #1 (permalink)
rickr01 wants to know Dino or Syn?
I bought a speedo on ebay from a Harley dealer, Model 67025-95c. The dealer said it would work fine On my 98 FXD with model number 67025-96c speedo. My dealer says no. If I install it the dealer wont accept a return, sooooo, who's right, anybody know for sure?
rickr01 is offline   Reply With Quote Quick reply to this message
Old 08-08-2005, 07:27 PM   #2 (permalink)
Wizwill wants to know Dino or Syn?
part number year suffix
I work at a Harley dealer in the parts department and generally, you don't need to worry about the letter after the suffix, but the number/year must be as called for. Harley often changes things from year to year and you can screw things up if you mix and it doesn't match.
Wizwill is offline   Reply With Quote Quick reply to this message
Old 08-09-2005, 03:26 PM   #3 (permalink)
Thanks Wizwill, it is going back I guess. Speedos and me sure don't get along! I can't stand seeing all that moisture in there and then the after effects of the stained glass when it finally does dry in the sun for 1/2 day. Harleys fix.
as the old s100 commercial states Perfect paint Perfect chrome and an old dull engine, although in my case its a speedo full of moisture!!
Old 08-17-2005, 10:39 AM   #4 (permalink)
Inquiring minds
Well I spoke to the Ebay seller who advertised the speedo as fitting up to 1998. He states he said it would fit and it does, in the housing, and that it will work but I would loose the signal cancellation feature. He said everything else between a 95 and 98 rear end. tire sproket etc including sending unit is the same and it should work as advertised. He won't take it back or exchange it sooooo Inquiring minds want to know?? Anybody sure of correct operation??
