Speedo quit! WTF? : V-Twin Forum: Harley Davidson Forums
Old 05-01-2005, 10:52 PM   #1 (permalink)
toddlerp wants to know Dino or Syn?
Speedo quit! WTF?
Is there a way to test the functing of a HD electronic speedometer? The fuse is fine, the wires under the counsel are okay. It just quit registering MPH and odometer/ trip meter in the middle of a ride.
The light works and all other functions on the bike work.
It is on my 2002 Deuce.
toddlerp is offline   Reply With Quote Quick reply to this message
Old 05-01-2005, 11:01 PM   #2 (permalink)
2005 Road King Classic
bbrowncods's Avatar
bbrowncods wants to know Dino or Syn?
I hate it when that happens. Now you'll have to go buy a new one with a tach built in or the nostalgic look, etc...
I try to think positive!
bbrowncods is offline   Reply With Quote Quick reply to this message
Old 05-01-2005, 11:16 PM   #3 (permalink)
Fourcats's Avatar
Fourcats wants to know Dino or Syn?
Do a Speedo Sensor search...
Fourcats is offline   Reply With Quote Quick reply to this message
Old 05-01-2005, 11:26 PM   #4 (permalink)
toybox99615's Avatar
toybox99615 wants to know Dino or Syn?
Talking digital speedometer testing
If the speedometer lights up when the bike is on the procedure goes something like this.
The basic test for a digital speedometer is:
turn on ignition and see if there is an odometer reading
yes there is odometer reading then press the trip button
does it change to the trip mode reading
yes no problem
no replace spedometer
No there is no spedometer reading then replace speedometer
If above is yes to the odometer and trip reading then turn off ignition
hold down trip button and turn on ignition (now your in diagnostic mode)
there are 10 readings in this mode. by pressing the button you move from one to another. If any problem exist the mode will read XX set if there is no promblem mode will read XX clear.
Depending upon which mode is set you can isolate the problem. For a good speedometer all modes are to be clear.
The exact diagnostic code are in the Harley service manuals. A fairly simple procedure to do. But a procedure that requires a manual for the charts.
The above is a short version from the H/D manual. I've done this on a few bikes and it really works well most of the time. Then of course there is the few times when things don't go as planned.
Once again this is another example of why you've got to have a manual for your bike. True H/D gets a lot for a manual. But if you did one procedure like the speedometer test and saved the cost of a service call at the dealer your ahead of the money game.
You are entitled to your own opinion but you are not entitled to your own facts.
(attributed to Daniel Patrick Moynihan)
toybox99615 is offline   Reply With Quote Quick reply to this message
Old 05-02-2005, 12:15 AM   #5 (permalink)
Harris
Guest
Posts: n/a
It sure sounds like your speedo sensor. The magnets on it get eventually pick up metal bits. Pull it and clean it off. If that doesn't work, you need a new sensor, not a new speedo. If the needle makes the sweep when you're in diagnostic mode, all the more reason to suspect this.
Harris
Old 05-02-2005, 12:33 AM   #6 (permalink)
I will look at the sensor. Thanks guys. Your replies are much appreciated.
Old 05-02-2005, 12:38 AM   #7 (permalink)
When I performed the test d02set was shown, all others were clear.
Old 05-06-2005, 09:20 PM   #8 (permalink)
Cleaned Sensor but to no avail
The sensor was full of chips, I cleaned and re-installed her. But after a quick test ide, she still does not work. Can the sensor be checked for functionality?
Old 05-06-2005, 10:11 PM   #9 (permalink)
Fourcats's Avatar
Good question, I don't know. Mine went out, I swapped it with another bike...and they got the problem . A new sensor is $55.
Old 05-06-2005, 11:37 PM   #10 (permalink)
road_king's Avatar
road_king wants to know Dino or Syn?
Yes ther is a way to test the speed sensor but it involves fabricating a test harness and using HD-41354 spedometer tester.
A couple easy things to verify are 12v on red wire to speedo sensor.
Also, make sure the black wire is a good ground.
I'd bet the sensor itself is bad as others have indicated.
road_king is offline   Reply With Quote Quick reply to this message
Old 05-07-2005, 12:04 PM   #11 (permalink)
sportydave wants to know Dino or Syn?
this happened to my bike twice ... I turned the ignition off and back on and it started to work ... I think it might be in the switch... but all is fine now and no more probs for now ...
sportydave is offline   Reply With Quote Quick reply to this message
Old 05-08-2005, 05:10 PM   #12 (permalink)
UPDATE Problem solved THANKS
It was the speed sensor. I replaced it and the speedo works, the idle is back to normal, and the turning signals cancel as they should. Life is good again.
Thanks a million fellas.
Old 05-10-2005, 09:26 PM   #13 (permalink)
t2597tb wants to know Dino or Syn?
I have a 2000 Road King Classic and the speedometer just quit working. It sounds just like the above problem. The speedometer and the odometer quit working and the turn signals don't cancel. I feel dumb asking this, but where is the speed sensor on my bike?
t2597tb is offline   Reply With Quote Quick reply to this message
Old 05-10-2005, 10:02 PM   #14 (permalink)
Fourcats's Avatar
The sensor is by the dip stick, takes a 3/16 allen. {You may have to pull the chrome cover on the starter to replace the sensor}
Old 05-16-2005, 07:55 PM   #15 (permalink)
I love to route the wire it is so much fun yea right.
