Brake light stays on - Page 3 : V-Twin Forum: Harley Davidson Forums
Old 12-09-2016, 06:31 PM   #31 (permalink)
captainhook455's Avatar
captainhook455 wants to know Dino or Syn?
Originally Posted by rootintootin View Post
Go here, look, look, and look some more. Should be able to find what you are looking for.
http://partsfinder.onlinemicrofiche....GŪ-CLASSIC-(FR)
thats some good help right there. Sounds like he was ready to pull his hair out.
tarheel
captainhook455 is offline   Reply With Quote Quick reply to this message
Old 12-10-2016, 02:57 PM   #32 (permalink)
ktfjammer wants to know Dino or Syn?
tarheel
I have no hair. lol
Thank you every one
ktfjammer is offline   Reply With Quote Quick reply to this message
Old 12-15-2016, 11:08 AM   #33 (permalink)
Well it looks like there was a short in the tail light socket. Got a new one from Harley and it is all good. When I went to Harley to get the part, they stated the part gets order a lot. I figure this is an ongoing problem. So if any of you are having the same issues and you know for a fact the front and rear switch along with the relay are good. Look at the socket. Wasn't able to narrow it until I was able to get my test light. So invest in one of those. Thank you everyone for all your help
Old 12-16-2016, 08:45 AM   #34 (permalink)
Eric road king's Avatar
Eric road king wants to know Dino or Syn?
whew well thank god that problem is behind you! Sometimes you get caught in a viscous loop, good job sticking with it.
" 2006 Roadking"
Eric road king is offline   Reply With Quote Quick reply to this message
Old 12-17-2016, 05:42 PM   #35 (permalink)
pb68slab's Avatar
pb68slab wants to know Dino or Syn?
Many times the sockets short because of corrosion. Be sure to apply a generous amount of a good dielectric grease to the inside of the socket and the base of bulbs
"Clowns to the left of me,
Jokers to the right!"
pb68slab is offline   Reply With Quote Quick reply to this message
Old 02-01-2017, 07:49 PM   #36 (permalink)
Brian Dumptruck wants to know Dino or Syn?
Just had this problem with my '05 Ultra. The cure, pull the brake lever and use a pick to pull the rubber seal away from the piston, use penetrating oil then reinstall the lever. Let the lever snap back out several times and that should cure the problem.
My cruise wouldn't set and the brake light stayed on all the time. turns out the piston was sticking in the master cylinder causing play in the brake lever leaving the brake light on. Just something else to look at in your case.
Sold the last Harley almost 40 yrs ago but like pi$$$ing into the wind, it's all coming back to me now!
Brian Dumptruck is offline   Reply With Quote Quick reply to this message
Old 02-01-2017, 08:00 PM   #37 (permalink)
Originally Posted by Dannyboy58 View Post
I did the same on my 04 flhti. Is there a little rubber "boot" over the plunger? If not this is your problem.
I pulled that little rubber seal off the plunger just a bit and sprayed penetrating oil in under it. Reinstalled the brake lever and then squeezed the lever and let it snap back time after time until there was no play left in the lever. My brake light went out and the cruise works great now.
Just something else to look at...
Old 02-11-2017, 10:22 PM   #38 (permalink)
Thank you everyone for your help. the socket was the problem
