Dealer Fix ... replace 15 amp breaker with a 30 amp breaker - Page 2 : V-Twin Forum: Harley Davidson Forums
Old 01-15-2013, 01:08 PM   #16 (permalink)
keye wants to know Dino or Syn?
93 horse.. I bought this scoot as a repo outa Florida....its old school and thats what I wanted...taking her to the dealer was the last thing I would do.....bought a repair manual off ebay and saved coin was my thinking...this being a repo i found lots of missuse and misscare, one issue by one issue I fixed them all, I knew I had a short under the seat, kept repositioning the harness as a short term fix, trust me that in those days with the fuse flickin I got to know the fuse or breaker real well, I got to know the heat that it gave off, there were 4 15 amp fuses, all silver to the look , than I ran into carb problems, I beleive that I started a good size post on this form, everyone helped with opinons, but the carb scared me and i took her in to the dealer, while there i asked if they could take a look at the wiring under the seat....they got back to me saying they fixed the wiring but the carb couls be a rebuild or different jets.....like an idiot I was all smiles that my short was fixed but the carb issue I decided to tinker...with the help of this site I found the problem, pin hole in the rubber seal at the manifold........sorry this turned out to be a long post, but damn as God is my witness I had 4 15 amp fuses.....and as for the lawsuit...small town, not into the drama, giving the small shop here in town my coin is well good......this weekend I will find the problem....thanx to the members with good info...I will rely on these posts but I will find it.......and Jammer, I bought a new HD H/lite connector and soldered and shrinkwrapped all the wires to spec....blue wire behind the fuse box still getting to hot to the touch, thanx for the reply
keye is offline   Reply With Quote Quick reply to this message
Old 01-15-2013, 02:24 PM   #17 (permalink)
jammer45u's Avatar
jammer45u is reading this now saying WTF is this? jammer45u is reading this now saying WTF is this?
Do you still get excess heat in the line when the headlight is unplugged?
I know it's a long shot, but ya never know. And it's good to eliminate all possible problems. Plus that could point you toward a bad ground vs short.
jammer45u is offline   Reply With Quote Quick reply to this message
Old 01-15-2013, 05:21 PM   #18 (permalink)
93Horse's Avatar
93Horse wants to know Dino or Syn?
Thanks KEYE,, sorry, knowing you bike history (read all of your post) and knew about your bike history. I agree with you,, it's foolish to replace a 15 amp with a 30 amp just to cover up the real problem... and your dealer is to blame,,, good luck
"Our lives begin to end the day we become silent about things that matter"
93Horse is offline   Reply With Quote Quick reply to this message
Old 01-15-2013, 07:42 PM   #19 (permalink)
think I am getting there....I drive transport and tonite had a nite off, so I started prepping the bike.....removed fuel tank console and have it laying on the side with all wire harnesses still hooked, removed fuel tank off bike and cut 4 tiestraps holding the main harness to the frame, there are 3 harnesses wrapped in 3 separate rubber sleeves under the tank.....all 3 have been moved side to side as I was cutting the straps.....held power cable to battery with my thumb and turned on ignition, ran high and low beams for a good 3 or 4 minutes, the fuse does not heat up now nor dos the wire, I hope that somewhere in one of those sleeves I find the problem I will know this weekend a great nite to all
Old 01-24-2013, 08:10 PM   #20 (permalink)
Rollmeaway's Avatar
Rollmeaway wants to know Dino or Syn?
Eh Keye
Outa curiosity were you ever able to have time in diagnosing your wiring issues?
We never even said a word,
And we rolled...
Dare...
2000 FXST - Carbed
Rollmeaway is offline   Reply With Quote Quick reply to this message
Old 01-28-2013, 10:43 AM   #21 (permalink)
I just spent the last week cutting the protective sleeves off the harrnesses and following every wire, Everything looks good and secured in the sleeves, all connections at lites, switches and grounds look good, i careefully sliced each sleeve and replaced and repaired after each inspection.....I have to go with a members early suggestion, the connector at the h/lite was badly melted as was the connector at the fuse box due to years of running lites, which have been replaced, soldered and shrinkwrapped, as I said before the blue wire coming off the fuse was badly burned and thinned out due to the heat, it has been soldered to a new connection......I run the lites now in low and high and there is no heat at the fuse, as i run the lites a put pressure on all the harnesses to see if the fuse flips, it does not, I gotta hope that the bad connections caused the original fuse popping and the 30 amp finally put the final nail in the coffin so to speak........for now everything seems good, hopefully as the ridingg season it stays good thanx to all you guys make a hopeless situation lead to a good day
Old 01-28-2013, 06:48 PM   #22 (permalink)
RustyG is reading this now saying WTF is this?
Just a thought. Could someone have put a higher wattage headlight on the bike? One that the wiring can safely handle?
Regards,
John
Everything is JMHO. Accuracy is not assured.
Originally Posted by Mark Twain
The more I know about people the better I like my dog. -
2007 VRSCX 0461 / 1400
2003 VRSCA Gone but not forgotten.
2002 Road King Classic
RustyG is offline   Reply With Quote Quick reply to this message
Old 01-28-2013, 06:58 PM   #23 (permalink)
Rollmeaway's Avatar
Eh Keye
Glad to hear you have things under control. Sounds to me like ya got the problem solved.
Cheers ...
And we rolled...
Dare...
2000 FXST - Carbed
Old 01-28-2013, 11:28 PM   #24 (permalink)
Rusty...yes the bike did have a H4 H/intensinty bulb which I have replaced also with a new H4 bulb......I will keep an eye on the fuse block as the riding season starts up for heating up, if I run into this prob again i will change back to a stock H/D headlite again thanx to all for the help and Rollmeaway thankyou for the much needed know how on wiring probs to all a great nite
Old 03-06-2013, 09:53 AM   #25 (permalink)
This is never ending....getting ready to do oil change, put new fuel in tank, fired the scoot up, no heating and lites h/lites working....problem I ran into was changing all lite bulbs in the dash for signals, nuetral switch, oil pressure.....oil pressure lite would not work, married ground to oil pressure over to turnsignal ground and it worked, did not want to start tearing wiring harness apart looking for the bad ground to the oil lite, since marrying it to another ground made her come alive, figured to leave it....tonite added fuel to tank and fired up the bike, the oil lite does not go off, at the switch I touched the switch wire to the motor and the lite comes on at the dash, its a new switch installed last summer, the tank is full of Amsoil with approx 4000 kms......now I am scared to fire her up......any ideas before I start dreading a oil pump failure.....I am ordering a oil pressure guage to manually see if there is oil pressure.....
