11-03-2012, 10:39 AM
Radio Installation Test
I bought a used Radio Tech am/fm radio from a member on this forum. Before I installed it, I wanted to bench test it first. The first thing I do is check the in line fuse for the hot wire on the radio wire harness. It's blown. So, I go get a bunch(just in case) of replacement fuses and lo and behold I pop two more.
I'm attaching the black wire to negative terminal. The red wire and the orange/white wire to positive terminal. As soon as I connect the red and orange/white wire to the battery the fuse pops.
I don't think I'm doing anything wrong and what has me worried is the fuse was blown when I received the radio.
Am I not connecting the radio correctly? I know the orange/white is supposed to go to a switch wire, but for testing purposes I think I can go directly to the battery, right?
I have verified that there is no short in the three wires from the battery connections through the deutsch plug connection in the radio wiring harness.
Reason: More testing information
11-03-2012, 12:37 PM
First off, do you have the correct size fuse??? Did you try just connecting the black to neg and red to pos???
11-03-2012, 01:18 PM
orange wire
First off, let me state I do not have any experience with motorcycle radios. Having said that, the orange wire on a car receiver is usually the remote wire that turns on other devices like amplifiers. It shouldn't cause a problem hooking it to +12 volts. But, you shouldn't need to connect it at all.
I hope this helps.
1999 California Motorcycle Company Softail Custom, S&S 88, RB Racing pro stock 2-1 exhaust. Super E with 32 and 74 jets. Daytona Twin Tec Ignition 1006. Wood W8 cam. New to me 2005 Electra Glide Classic, stock for now, but not for long...
11-03-2012, 01:59 PM
I've tried just hooking up just the red and black. The fuse immediately blows no matter which order I connect them in. The radio came with a 5A fuse. I'm using 5A fuses as replacements.
11-04-2012, 07:07 AM
I completely disassemble the entire unit isolating each component board. I then hooked each board and associated parts. in sequence starting at the radio wire harness. There were three primary boards and some misc compenents(ie. LCD display, push botton interface, relays). I just hooked each one in turn to the wire harness and using the multimeter checking for shorts, nothing obvious. I then disconnected everything again, hooked up the wire harness to a battery then reassembled each component in turn to see which one was going to pop the fuse, nothing?
Radio appears to work now. Didn't change the red,oragne/white, black battery connections. There might have been a poor connection on the circuit boards and I accidentally fixed it as I disassembled and reassembled the parts.
11-04-2012, 08:59 AM
Look closely at the wiring harness where it goes into the case, sounds like more of a short than an open wire.
| Sponsored Links |
