11-03-2012, 01:11 AM
Weird Front Blinker Issue
So I am rewiring all new blinkers on my FXR.
I bought some of those cheap LED arrow blinkers off ebay to stick to my mirrors. Though it would be a cool look. Anyways, when I wired them up and pressed the blinker button, the rears don't work and the front just stays on, instead of blink (This is an old FXR where you have to HOLD the button down and they blink). When I wired up an older set of blinkers, it works just fine. Only thing I can think of is the difference in wire gauge. The eBay ones has like, ****, 24-26 gauge wiring and my other blinkers are like16-18 gauge.
Would that cause it not to work?
1972 Superglide FX: Rebuilt, Super E, Drag pipes (FOR SALE PM ME)
2005 Sportster 1200: Thunderheader, SE ICM, SE carb upgrades, pretty stuff
1985 FXRS-SP: (looks VERY different than the pic. More black now) Dyna 2000 ICM, Twin Tec II Single Fire, Mikuni 42mm, S&S intake, Progressive springs, need money for Thunderheader and mid-controls! Have lot's to trade and $ if you have one for my bike!
11-03-2012, 02:39 AM
All I know on wiring. Is if you change wiring thickness. The thicker wire will use less amps without heating up. That said. The blinker internals use a bi-metal that heats up with an amperage called for on the system. The bi-metal bends and breaks the contac.
Once broke, the bi-metal cools down and bends to make the contac again. An on going process. With the larger size wire, perhaps it's letting less aperage thru and thus. Less amps thru to make the bi-metal work? JMHO.
11-03-2012, 07:47 AM
with the LED's you will need a load resistor to make the signals work correct there is less resistance with the led so the flasher will not work properly badlands and custom dynamics will both have them .
LoneEagle
11-03-2012, 11:51 AM
OK, do you have links to these?
11-03-2012, 11:55 AM
How many Ohms ya think?
11-03-2012, 12:30 PM
Should be 6 ohms, I'd go with 50 watt vs 25 watt as well for better heat management.
OE bulbs draw about 2 amps, formula you want is R=V/I, 12v/2a= 6 ohms. You're going to want to wire these in parallel to the turn signal lamps as well.
Check fleabay for the wirewound resistors, or load equilizers. I've picked them up there before, look for the kind with built in aluminum heat sinks, and don't mount them on or near plastic. They can get pretty toasty.
'03 FXSTB -Wild One WO500's, D&D Lowcat, Corbin Hollywood solo, 3.5" extended Fwd controls, Mikuni HSR42.
'94 FXR Superglide - In progress
11-03-2012, 11:20 PM
What do you mean to wire them parallel to the turn signal lamps as well?
11-04-2012, 01:11 AM
11-04-2012, 01:52 AM
Those are perfect, same kind I've used. Work well. As for parallel, you are going to "bridge" across the turn sig circuit pos to neg, not splice in line (series).
Easiest way to do this is to tap splice one lead of the resistor into the Positive lead for the sig and run the other lead to the chassis ground the neg battery term is landed on. Use a ring term for this so you don't have to tap any more wires.
If you can, only tap into the secondary harnesses (after the plugs, on the signal side), try not to hack into the main harness, makes things way easier down the road for diff mods and helps anyone who has to dig into the elec system to troubleshoot.
Also heat shrink any taps with dual wall adhesive heat shrink to keep the moisture out.
Good luck! Hope that helped some.
11-04-2012, 08:58 AM
Didn't notice before, but the auction had the parallel diagram...here you go
11-04-2012, 12:43 PM
Ok, I will order those. Will try to hide the resistors behind the headlight so they aren't visible. Thank you for the help!
11-04-2012, 12:45 PM
Yeah I saw that parallel wiring diagram. haha
11-04-2012, 12:55 PM
No prob, let us know how it goes! Resistors are about 1-1.5" long so behind the light may not work. I usually end up somewhere around the battery and extend the wires if I need to. IDK, under the sideplates on the FXR might be a good spot too...lol let me know, I picked up a '87 FXRS-SP, if all goes well it (in storage till I close on my new garage...um I mean wifes new house lol) should be this winter's project.
11-04-2012, 01:09 PM
Awesome. Your Soft tail is really nice too! You'll love the FXR though.
11-04-2012, 01:26 PM
Thanks man, you have some nice bikes too.
Had a '91 FXR, so I already know I'll love it lol! Sold it before I moved to IL, kept the softie since it was/is the only one I ever bought new
mark me up as one of those "wished he hadn't" guys, but hey we all make mistakes
| Sponsored Links |
