Help on Setting Up Crane HI-4TC : V-Twin Forum: Harley Davidson Forums
Old 11-01-2012, 08:54 PM   #1 (permalink)
Vitsing wants to know Dino or Syn?
I could us a little help for the position settings on a HI4TC. I don't have tools and would to get closer to proper settings. Can someone suggest the position numbers for the following configuration?
Screaming Eagle 95ci (1,550cc) upgrade:
SE High Performance Heads w/compression releases
SE 10.5:1 Hi-Compression Pistons
Andrews TW-60 cam with Andrews chrome molly push rods
Minkuni 42mm w/over jetted Carb
Crane Fireball HI-4TC Performance Ignition
Super Trap 2 into 1 Exhaust with Super Trap open end cap and 9 disks
SE Plug wires
Thanks,
Ken
Vitsing is offline   Reply With Quote Quick reply to this message
Old 11-11-2012, 07:25 AM   #2 (permalink)
Slick03 H-D's Avatar
Slick03 H-D wants to know Dino or Syn?
On my 03 with a built 107, offset was-1, initial was +1,, slope was +2 and revlimiter was at 6250, but that was on a 107 with actually a little to much compression (82cc heads with .030 cometic gaskets & s&s 585g cams which gave me 215 ccp) so I had to run mine on the conservative side, anything more aggressive and it gave me detonation issues, and I ran ethanol free 93 octane gas & I carried octane booster in case I had to buy gas out.
2013 110th anniv dark bronze metallic & black bagger.
107 motor, heads by V Twin Perf. T-Man 625 cams
Drago's Dragula 1, 2 into 1 pipe with 2.55 baffle
H-D Ventilator air cleaner, Dyno by Doc/115hp & 120tq
CVO adjustable rear shocks
Leather C&C seat
Freedom 8" dark smoked windshield
Painted inner fairing & Fat Boy frt fender
Streamliner boards/pegs
Nostalgic bag rails
10" Yaffe mini apes
More to come much to my wife's dismay
Slick03 H-D is offline   Reply With Quote Quick reply to this message
Old 11-11-2012, 10:39 AM   #3 (permalink)
rootintootin wants to know Dino or Syn?
Let me refer to the Blue book: 1-0-0-5-6-3. What year are you talking about? I believe they have a different module for 04 to 06 TC88s. That one doesn't have as many wheels as the older version.
Real similar combo, not sure about the SE heads, I have Zippers stage III with 83cc chambers and 1.99/1.65 valves. My Supertrapp has I think 18 discs and the open cap. And I went up to 45mm on the carb, didn't make any difference to the ignition.
Last 2 numbers are for forged SE pistons. If you have the cast version, probably don't want to spend much time over 6K, so set at ...6-0.
You're looking at mostly adjusting in the 3rd and 4th positions. I'm usually in the 0-1 (3rd) to 5-6 (4th) range in these positions, depending on the ambient temp and how much pinging I get. You can lower either to ease it up a bit, there isn't a "1 perfect setting" for all conditions. I always turn it down a notch or so in the summer and dial it back up when cold weather arrives.
When I bought the bike from a friend, he had cast flat top SE big bore slugs and Andrews 37Gs and used 1-0-1-6-6-0.
2000 Lowrider, 86K miles
95" SE Forged pop-ups
S&S 585Gs on Delkron plate
Zippers Stage III CNC heads
45mm Mikuni and Supertrapp(S.E.) 2-1
Lots of other stuff Harley took years to fix
rootintootin is online now   Reply With Quote Quick reply to this message
Old 11-12-2012, 05:29 AM   #4 (permalink)
Oops, old timers disease kicking in again. I pulled the seat to check because something didn't sound right. My curve is set at 8, been there since summer. One more click to go for the most aggressive curve. So that makes 1-0-0-8-6-3. Sorry about that.
Here's a couple of links if you don't have any instructions.
http://www.cranecams.com/uploads/ins...s/90003170.pdf
http://www.cranecams.com/uploads/ins...s/90003180.pdf
Old 05-18-2015, 08:31 PM   #5 (permalink)
porschemann wants to know Dino or Syn?
I know this is an old thread, but wondering if you ever got your setting sorted, and how it runs now.
porschemann is offline   Reply With Quote Quick reply to this message
