how to know if the starter clutch went bad? : V-Twin Forum: Harley Davidson Forums
Old 10-19-2012, 07:00 PM   #1 (permalink)
Magnum44 wants to know Dino or Syn?
Hi all,
My 2003 RK is having problems with the starter, it spins but it doesn't engage the clutch gear. I've pulled out the starter and dismantle it. It is the first time so I dont know what to look for. How do I know if the starter clutch went bad or if it is any other part?
Should the jackshaft only spin in one direction? I checked the starter clutch by hand and it spins both directions, is this normal? how do I know which part is wrong?
Thanks all!
Magnum44 is offline   Reply With Quote Quick reply to this message
Old 11-07-2012, 08:04 PM   #2 (permalink)
harley-gearhead wants to know Dino or Syn?
The shaft will turn either direction turning it by hand. And when you pull out on the gear/shaft of the starter it should feel like it is spring loaded (because it is), and should spring in and out fairly easy, by hand. And if it doesn't, the spring may be broke, or the shaft may be gaulded up not letting it move freely.
harley-gearhead is offline   Reply With Quote Quick reply to this message
Old 11-09-2012, 06:28 PM   #3 (permalink)
ASA Lives
Ultra89Rider's Avatar
Ultra89Rider wants to know Dino or Syn?
But the Bendix will move only one direction. If the gear moves in both directions, I would replace the Bendix.
la'Hom Ho'neH jorDe' vestai-VamPyr
wa'DIch, IKRV Hurgh HaP, Ring of Fire Fleet
Order of the Bat'LetH
"lIgh tlhab"
(Ride Free)
Ultra89Rider is offline   Reply With Quote Quick reply to this message
Old 11-11-2012, 04:42 AM   #4 (permalink)
Finally solved it. The problem was the starter clutch. Moved to an All Balls clutch.
The funny thing is that the stealer wanted me to pay 600€ for a new stock starter plus installation (that makes approximately 850€) and I solved the problem myself for 57€ + primary oil.
Thanks for the replys.
2003 FLHR, Kerker turn down slip-ons, S&S 510G Gear Drive Camshaft, S&S Stealth Air Filter, Mikuni HSR-42 Easy Kit, Jagg oil cooler.
