AntiGravity batteries : V-Twin Forum: Harley Davidson Forums
Old 10-14-2012, 09:11 PM   #1 (permalink)
rob71458's Avatar
rob71458 wants to know Dino or Syn?
Does anyone discount these batteries. The one that is recommended for my bike is $469.00. Yikes !
07' FLHRSE3 124", Paul Matyka ported SE110 heads, S&S pistons/cylinders,11.5 cr, 58/62 HPI TB, 640G's, Bandit clutch, Baker DD7, IDS, 2.79 gearing, Stock Compensator, D@D Borzilla QB, K&P oil filter, Jagg ten row oil cooler, Big Sky oil cooler fans, Lenale fan, Redline oils, TWR stabilizer, Glide Pro mount. Big Boyz Tune.
rob71458 is offline   Reply With Quote Quick reply to this message
Old 10-14-2012, 10:49 PM   #2 (permalink)
SirJYK wants to know Dino or Syn?
What on Earth are those?
1999 California Motorcycle Company Softail Custom, S&S 88, RB Racing pro stock 2-1 exhaust. Super E. Daytona Twin Tec Ignition 1006. Wood W8 cam. New to me 2005 Electra Glide Classic, stock for now, but not for long...
SirJYK is offline   Reply With Quote Quick reply to this message
Old 10-14-2012, 11:24 PM   #3 (permalink)
BOUTYM's Avatar
BOUTYM is reading this now saying WTF is this? BOUTYM is reading this now saying WTF is this?
I don't know how long these have been around, but for the price I don't think the cost justifies any benefit.
Why is it that people are often labeled racist only because their comments are taken out of context?
BOUTYM is offline   Reply With Quote Quick reply to this message
Old 10-15-2012, 12:17 AM   #4 (permalink)
Topgeye wants to know Dino or Syn?
It says $359.00 here. Geesus!
http://www.hardracing.com/AntiGravit...eBatteries.htm
Topgeye is offline   Reply With Quote Quick reply to this message
Old 10-15-2012, 07:25 AM   #5 (permalink)
rob71458's Avatar
Originally Posted by Topgeye View Post
Thanks for the link, but that is the 20 cell. I will give them a call. AntiGravity's website recommends the 24 cell, which lists for $469.00
Old 10-15-2012, 08:50 AM   #6 (permalink)
sporty952 wants to know Dino or Syn?
Are they compatible with the charging system in the bike?!?
Seems like lithium chemistry wants a completely different
charging strategy than lead-acid and stock regulator certainly
isn't prepared to handle that...
-W
sporty952 is offline   Reply With Quote Quick reply to this message
Old 10-15-2012, 09:39 AM   #7 (permalink)
rob71458's Avatar
Good question. ??
Old 10-15-2012, 11:10 AM   #8 (permalink)
BOUTYM's Avatar
I would suspect they add some kind of circuitry in the case to make compatible the charging system and to prevent overcharge since improperly charging a lithium can make bad things happen. Can't for the life of me see a manufacturer taking the risk of not doing something like this.
Old 10-15-2012, 11:32 AM   #9 (permalink)
rob71458's Avatar
Not sure why they would recommend a 720cca battery either.
Old 10-16-2012, 03:25 AM   #10 (permalink)
Locodave's Avatar
Locodave wants to know Dino or Syn?
Wow! How many regular batterys you can buy. And life span on each. To vrs that batterys cost? " I can buy standard 4-5 batterys for the price of that one".
Locodave is offline   Reply With Quote Quick reply to this message
Old 10-16-2012, 08:40 AM   #11 (permalink)
rob71458's Avatar
I hear you, but a standard battery is having a hard time firing up my 124. I would rather have reserve cranking power than not enough. Get's pretty embarrassing, when your hot rod bike won't start well.
Old 10-16-2012, 09:01 AM   #12 (permalink)
Look carefully at the cell count in the battery (i.e. the series count,
not the total cell count) and calculate the required charge voltage...
Does it come close to what the stock regulator is set for and is it
compatible with the ECU (i.e. will the ECU report over/under
voltage all the time)? And, if the battery is chronically undercharged
(as a result of the regulator setpoint being too low for the battery)
you won't see the CCA you are looking for...
Old 10-16-2012, 09:46 AM   #13 (permalink)
BOUTYM's Avatar
Comp releases?
Old 10-16-2012, 11:45 AM   #14 (permalink)
rob71458's Avatar
What are those? Kidding. Yes, I do have compression releases.
Old 10-16-2012, 12:19 PM   #15 (permalink)
LMoto wants to know Dino or Syn?
Li batt
what are the dimensions of your battery box ? L x W x H
Lithium battery suppliers use differant rated cells, thus their packs have to be bigger (more cells inside ) to get the desired cranking power.
LMoto is offline   Reply With Quote Quick reply to this message
