Quick tail light wiring question : V-Twin Forum: Harley Davidson Forums
Old 06-23-2012, 08:38 PM   #1 (permalink)
OldTyme's Avatar
OldTyme wants to know Dino or Syn?
I bought a tail light off Ebay. The only "instructions" are here....
Linkie to picture
I have a PDF manual for the bike. Do is "assume", the blue goes to the blue, the red goes to red/yellow, black ground.?
I assume if I want to use the tag light....I wire the white w/ the blue & the black w/ the ground?
Just making sure before I put it on.
(oh yeah) 01 FXDL.
Also. Can I find the wire-end plugs (that will plug into the existing wire harness @ any auto parts store? I figure this way would be the easiest instead of splicing wires)
OldTyme is offline   Reply With Quote Quick reply to this message
Old 06-24-2012, 10:34 AM   #2 (permalink)
Dave in Texas's Avatar
Dave in Texas wants to know Dino or Syn?
Blue is the running light wire....meaning when the key is On all the running lights are illuminated. The 'tag' light should be the same. Black is always Ground. R/Y is Brake light
Those connectors can be found at the 'dealer' or maybe a electronics-parts store. If you decide to splice instead, make sure you solder and shrink-wrap connection. Lotsa vibration back there.
Dave
Veteran/Retired IBEW Lu520
2003 FXDL Stg 1 AC, SE slipons
CVP Tuner carb kit
Andrews Hyd kit w/21n cams
Ohins shocks, Intiminators in forks.
Mustang Vintage Solo & Pass seat
15" WindVest
J&S Dyna lift
Dave in Texas is offline   Reply With Quote Quick reply to this message
Old 06-24-2012, 11:55 AM   #3 (permalink)
OldTyme's Avatar
Thanks Dave.
I went to Autozone & they had nothing that size. I think I'll spend the few extra bucks & find the right ends so I can just plug it in. I guess finding a cheap light has it's disadvantages.
Old 06-24-2012, 06:23 PM   #4 (permalink)
OldTyme's Avatar
Just a heads up. I found the terminal connectors @ O'Reilly Auto Parts (I think they are nationwide?)
The part # was BWD CT719 .... $0.59
It's working. Thanks.
Old 06-24-2012, 07:08 PM   #5 (permalink)
Good to know! Prolly be 2x that cost at the dealer.
Dave
CVP Tuner carb kit
15" WindVest
J&S Dyna lift
