low voltage code check engine light battery light after filling with gas : V-Twin Forum: Harley Davidson Forums
Old 05-31-2012, 08:02 AM   #1 (permalink)
ken80 wants to know Dino or Syn?
Low voltage code shown on my 08 streetglide 20000 miles serious help needed on this one, battery low voltage code, check engine and battery "IDIOT" lights on right after filling with fuel. Volt gauge dropped to 11 for about 3 blocks then jumped back to 14 and stays there. I checked and reset the code in the garage checked battery was still around 12.5 volts. This has happened to me twice about 2 months apart, same exact story both times. I am thinking it may be loose connection at the voltage regulator at least praying. Anyone else have issues like this if so your experience and the repair needed would be greatly helpful in trying to fix this problem in my garage.
ken80 is offline   Reply With Quote Quick reply to this message
Old 05-31-2012, 09:00 AM   #2 (permalink)
guydoc77's Avatar
guydoc77 wants to know Dino or Syn?
Regulator itself?
2008 Road Glide
Phoenix Customs Bagger Brace
Glide Pro
Clearview windshield
107
CP flat tops
R&R Stage 3 heads, .030 gasket, 82cc chambers
Trued, welded, and balanced crank by Hyperformance
TMan 590 cams
SE AC
HPI 54mm TB
Supermeg with open cap and 15 discs
TTS tune by BVBob
2003 Indian Scout Deluxe
Aspen White (got it for my wife)
S&S "SuperStock" 88"
12" apes
Scary fast!
guydoc77 is offline   Reply With Quote Quick reply to this message
Old 06-01-2012, 06:27 AM   #3 (permalink)
jpooch99 wants to know Dino or Syn?
Could be the voltage regulator, alternator stator - or any of the associated wiring and/or connections, loose ground wire(s), loose connection at the battery, dirty contacts in the main ignition switch etc.
jpooch99 is offline   Reply With Quote Quick reply to this message
Old 06-01-2012, 08:24 AM   #4 (permalink)
Huh? What?
BlueCamel's Avatar
BlueCamel wants to know Dino or Syn?
My 2012 RK had the same symptoms. Gassed up. A few miles later check engine and batt came on for about 2mi then went off. Had the dealer pull the codes and found low batt at 12.4v where the min value was was 13v or something.
Dealer said they've seen a number of the new bikes coming back with faulty charging systems. I'm waiting to hear what parts they replace.
~bc :: 2012 Road King
BlueCamel is offline   Reply With Quote Quick reply to this message
Old 06-01-2012, 07:12 PM   #5 (permalink)
Blue Camel please reply once you find out what parts are needed thank you.
Old 06-02-2012, 10:31 PM   #6 (permalink)
mlewis wants to know Dino or Syn?
I had a ‘low voltage’ code once on my older model FLH, first startup on a cold morning and rode the whole day without any problems. When I read up on the requirements to log a low voltage code, the manual claimed a battery voltage of something like 9.5 volts or less.
To investigate further, I placed a voltmeter across the battery terminals and hit the starter. The voltage I recorded was just below 10 volts. So a cold morning start could easily dip battery voltage lower. Now the battery that I had at the time was a very good brand, but it was six years old with many miles on it.
I bought a new battery soon after and never logged another low voltage code in the last four years.
mlewis is offline   Reply With Quote Quick reply to this message
Old 06-05-2012, 10:09 PM   #7 (permalink)
Huh? What?
BlueCamel's Avatar
Shop said they got the parts replaced but it'll be a day or two more while they wait on some chrome to arrive. You are supposed to put new parts on every time you take it in, right?
Old 06-10-2012, 09:37 AM   #8 (permalink)
Huh? What?
BlueCamel's Avatar
The main parts replaced were the stator assembly (29987-06B) and the voltage regulator (74505-09). Work done under warranty of course.
Old 06-11-2012, 07:18 PM   #9 (permalink)
Thanks BC for the info I sure hope that settles the problem for you. Gonna buy the parts and attempt to swap mine out. Thanks again for your posts.
Old 06-12-2012, 05:34 AM   #10 (permalink)
There are very simple tests to check the stator before you buy a new one. If it checks OK then you'll know its the regulator and will only have to replace that (MUCH easier than a stator) and you'll save some $$$ too.
Good luck.
Old 06-20-2012, 09:45 PM   #11 (permalink)
HogDreamer's Avatar
HogDreamer wants to know Dino or Syn?
My bikes in for service right now for the same issue. First time the "check engine" and "battery" idiot lights came on it lasted only about 100 feet of riding.
The next time, a few weeks later, they stayed on about 1 mile. Battery volt gage also dropped below 12 volts both times and then when back up around 14.
I checked the battery connections just to be sure they were tight and they were. No problems for another couple of weeks but this time the same lights and voltage reading lasted 5 miles. At this point I arrived home.
I hooked up my battery tender just to be sure it wasn't a battery issue. The next morning my battery showed fully charged. Started the bike up and everything was acting normal again.
This past Sunday I made a couple of short rides and noticed that while the idiot lights did not illuminate, the voltage was reading low every once in a while on the gage.
Took the bike in for service this week and was told today that I need a new voltage regulator. Doesn't matter to me if it is the stator or the regulator as I have the extended service plan. Wonder how many miles the average stator lasts?
HogDreamer is offline   Reply With Quote Quick reply to this message
Old 06-21-2012, 05:35 AM   #12 (permalink)
The stator on my '82 shovel quit at about 25k miles and the one on my '94 Dyna fried at about 30k. Both failed within a week of each other!
I seem to remember reading that OEM units generally last around 35k or so on average. Don't know if that's true or not, since neither of mine made it even that far!
