Yellow engine and red battery lights on an 06'Road King : V-Twin Forum: Harley Davidson Forums
Old 07-14-2011, 01:26 PM   #1 (permalink)
Lukas's Avatar
Lukas wants to know Dino or Syn?
Hi Friends,
I write in behalf of my mate having problems with his fuel injected Road King 06'.
After starting the motor up yellow engine light appears on the speedo. Then after while red battery light shows up. After reving the engine up and short riding lamps are gone. After some more time of the ride the story is back: first yellow and then red light show up again. Very irregular. No patern. Sometimes more offen, sometimes less. Bike rides normally, no isues. The battery is charged efficiently. Anyone of you has idea what is going on? I can fight with the pistons, cranks and heads but I am scared of electricity
Thanks in advance for help
Road King 2003
98" CP pistons, domed +3ccm
CR 10.1:1
cylinders bored and honed by myself
heads-ported and milled by myself - 84ccm chambers
030 Cometic gaskets
S&S 570 cams
S&S SUPER E carb
Dynatec 2000 ign.
HIvol oil pump
Heritage Softail 2003
95 flat top pistons
030 cometic, 0 deck
static compression ratio 9.82:1
Andrews tw37b cams
S&S super E carb
Crane ignition Fireball H4
87 Hp, 107 FTLB of torque
____________________________________________
RIDE NOW, WORK LATER!
Lukas is offline   Reply With Quote Quick reply to this message
Old 07-14-2011, 03:20 PM   #2 (permalink)
LoneEagle964's Avatar
LoneEagle964 wants to know Dino or Syn?
you can look at this thread http://www.v-twinforum.com/forums/tw...uble-code.html
pull the codes and see where that may lead you and perhaps someone else may have other ideas.
Check to be sure all batt connections are tight also .
LoneEagle
LoneEagle964 is offline   Reply With Quote Quick reply to this message
Old 07-15-2011, 03:26 AM   #3 (permalink)
Lukas's Avatar
Thanks Lone, will check follow instruction.
Ride safe!
Road King 2003
CR 10.1:1
030 Cometic gaskets
S&S 570 cams
S&S SUPER E carb
Dynatec 2000 ign.
HIvol oil pump
95 flat top pistons
030 cometic, 0 deck
Andrews tw37b cams
S&S super E carb
Old 07-21-2011, 04:32 AM   #4 (permalink)
Lukas's Avatar
bad VR
Checked codes. It says: low voltage. Battery is not charged. Measured voltage on the battery connections. Low. Alternator stator is ok (checked follow manual instr.) but found that vr is damaged. Swap with another one from electra and system is working properly...
Road King 2003
CR 10.1:1
030 Cometic gaskets
S&S 570 cams
S&S SUPER E carb
Dynatec 2000 ign.
HIvol oil pump
95 flat top pistons
030 cometic, 0 deck
Andrews tw37b cams
S&S super E carb
Old 07-08-2015, 10:16 AM   #5 (permalink)
ashleystpc wants to know Dino or Syn?
have the same problem I changed vr and stator and still doing the same and still code p0562 comes back after riding 10 to 15 miles
ashleystpc is offline   Reply With Quote Quick reply to this message
Old 07-08-2015, 10:25 AM   #6 (permalink)
self banned
Road King Cole's Avatar
Road King Cole is still riding a stock bike Road King Cole is still riding a stock bike Road King Cole is still riding a stock bike
Have you put a voltmeter on the battery and tested when: off, idle and high idle/charging?
rkc
2016 Ride of the Year Winner!
Road King Cole is offline   Reply With Quote Quick reply to this message
