Pin Connectors for Wires Going To Connectors? : V-Twin Forum: Harley Davidson Forums
Old 03-03-2011, 05:55 PM   #1 (permalink)
kshapiro wants to know Dino or Syn?
OK...the PO removed the rear turn signals by pulling the wires out of the back of the connectors instead of just cutting the wires. I need to either crimp or solder on new male , pin type, ends on my new wires to insert into the back of the connector block. Hope I'm making myself clear here. Do these come in different sizes? Are these a dealer only item? Help!
kshapiro is offline   Reply With Quote Quick reply to this message
Old 03-03-2011, 06:09 PM   #2 (permalink)
jammer45u's Avatar
jammer45u is reading this now saying WTF is this? jammer45u is reading this now saying WTF is this?
Deutsch connectors and pins come in different sizes. You could try the dealer, I think they may have them, if not JP Cycles has them.
jammer45u is offline   Reply With Quote Quick reply to this message
Old 03-03-2011, 06:19 PM   #3 (permalink)
How do I assess what size mine are? Do they solder or do I need special crimpers? Easier to just buy new connectors?
Old 03-03-2011, 06:45 PM   #4 (permalink)
jammer45u's Avatar
Yeah, a new connector would be easier.
There is a special crimping tool, I'm not sure if you need it or not. You may be able to install a new pin with regular wire crimpers, or have a dealer or electrical shop crimp it for you.
There are two or three different manufacturers of wiring terminals. A good automotive electrical shop could probably help you identify, find and install that pin.
Old 03-03-2011, 10:07 PM   #5 (permalink)
2000FiveOh wants to know where he is and how he got here
I took a pair of side cutter pliers and made a crimper. A little dremel work to the cutters and they work great. i always solder the pins even if I crimp them. Dealer can get you the right size pins for a couple bucks. You dont need to buy the entire connectors.
2000FiveOh is offline   Reply With Quote Quick reply to this message
Old 03-03-2011, 10:15 PM   #6 (permalink)
Thanks...appreciated.
