magnets out of place in rotor : V-Twin Forum: Harley Davidson Forums
Old 10-25-2010, 09:36 AM   #1 (permalink)
jbxmn's Avatar
jbxmn is on a distinguished road
I have a 2000 Ultra that quit charging. No ac output from the stator. Pull the rotor and found nothing wrong with the stator. I inspected the rotor and found that the magnets had all slide together. They appeared to have come unglued. Has anyone had that happen? Does anyone know what the cause could be? Can I glue the magnets back or do I just need to replace the rotor?
jbxmn is offline   Reply With Quote
Old 10-25-2010, 09:59 AM   #2 (permalink)
I'm Paid Up...
If the stator checks out ok, the magnet shifts would be the culprit. For the service time involved to re do it the second time, why reglue it?
DR_DEUCE is offline   Reply With Quote
Old 10-25-2010, 11:28 AM   #3 (permalink)
jbxmn's Avatar
If I can reglue the magnets, I'd save a couple of hundred bucks. I shopped the rotor last night and 45 amp rotor is $154 more than the standard rotor.
I still don't understand what caused the magnets to shift. The bike has 75K. I replaced the stator a couple of years ago. I've just never seen the magnets shift.
Old 10-25-2010, 11:59 AM   #4 (permalink)
DEW2112's Avatar
DEW2112 is on a distinguished road
Somewon may have used an air impact wrench to tighten the comp. sprocket nut.
1982 SHOVEL - 96"
2002 FLHT STD
DEW2112 is offline   Reply With Quote
Old 10-25-2010, 01:59 PM   #5 (permalink)
Zwiehund's Avatar
Zwiehund is on a distinguished road
It is a fairly common problem, I have had it and fixed a couple others. Never tried to re-glue it, but if I did, I would clean the snot out of all the pieces and re-glue with either slow setting epoxy or JB weld, clamping everything in place while it dried. Not sure of the temp requirements for that location, but I'd bet 250 would be adequate. Thing is, them sliding all together saved the stator. They don't always do that, sometimes they come off and eat the stator, so a new one might be more cost effective in the long run.
2004 FLHTCI with Khromewerks Mufflers, Fullsac headers, Stage I Download, Dobeck TFI, Big Sucker, Saddlemen Gel Seat, Windvest Windshield, Cruise, HD Stainless Pullbacks, Throttle-Up Touring Stabilizer, Andrews 21N Cams, Herko Hydraulic Tensioner Upgrade Kit, Hogtunes Sound.
A perfection of means, and confusion of aims, seems to be our main problem.
Albert Einstein
Zwiehund is offline   Reply With Quote
Old 10-25-2010, 02:04 PM   #6 (permalink)
jbxmn's Avatar
Nope; I've always used a torque wrench to tighten the compensator nut. I use an impact to remove it. No one has put a wrench on it but me.
Old 10-25-2010, 02:44 PM   #7 (permalink)
TIMTOOLMAN is on a distinguished road
the 0lder laminated rotors did this a lot in 2000. there is upgraded part number to a solid piece rotor
2009 ultra
hillside 107
hillside stage 4 heads with grooves
woods 400-6 cams
woods directional lifters
H.P.I. 54 MM 2 piece T.B. with 1.800 intake runners with S.E. 5.3 injectors
s&s p rods
billet rocker supports, .030 offset
fulsac x pipe
Reinhart slipons
tts Tuner
doherty p/p intake modified for hillside big green air filter
S.E. compensator
30 tooth pulley
big sky dual oil cooler fans
HTCS AW/SW USN RET,
!20hp /120 Trq
TIMTOOLMAN is offline   Reply With Quote
