ABS light : V-Twin Forum: Harley Davidson Forums
Old 12-02-2009, 11:50 AM   #1 (permalink)
gamb wants to know Dino or Syn?
Smile ABS light
abs light is on on tach display. HD tech checked it out,brake system is find,but he did not know how to cut off lite. any idea? thanks
gamb is offline   Reply With Quote Quick reply to this message
Old 12-02-2009, 04:52 PM   #2 (permalink)
cata5803's Avatar
cata5803 wants to know Dino or Syn?
If the ABS is the same as 4 wheelers the brake system is or should be fine. The anti lock brake system isn't working. Ussually when light stays on there's a problem with the ABS. A HD tech checked it out ?? You should be able to find a code which will tell you the problem. I don't know how Harley does this. With their computor,??
cata5803 is offline   Reply With Quote Quick reply to this message
Old 12-08-2009, 12:18 AM   #3 (permalink)
secretsquirrel wants to know Dino or Syn?
they do it with their computer digital technician
secretsquirrel is offline   Reply With Quote Quick reply to this message
Old 12-08-2009, 07:25 AM   #4 (permalink)
Coolmaker's Avatar
Coolmaker wants to know Dino or Syn?
If the light is on, the ABS has a problem. Tech does not know what he is doing.. Go to another dealer...
Coolmaker is offline   Reply With Quote Quick reply to this message
Old 12-08-2009, 02:26 PM   #5 (permalink)
strokerjlk's Avatar
reset your codes with the trip meter. sorry cant expain it.
I just have to do it to know what I am doing.
I have to do every time I dyno a abs bike. if the front tire dosent move and the back does it throws a code.
well it doesnt throw a code every time but it does have to go throught the reset procudure.
do a search for reseting codes on here I have seen it explained in detail.
07 ULTRA
AMRA
SE 218
DR 218
Old 12-20-2009, 08:51 AM   #6 (permalink)
DocDyna wants to know Dino or Syn?
ABS Light but Non ABS Bike
I asked this question before, Glad to see another person ask. On my Ultra the ABS light is ON but the bike does not have the ABS system. No codes on display to reset. Any Suggestions???
2008 Ultra Classic; Kameleon Blues / Prism Effect; 107"; V & H 2 into 1 Pro Pipe Ch; R & R Stage 4 Heads; Roller Rockers; Beehive Springs; Smith Bro Rods; SE Comp & Clutch; Weisco's @ 10.8/1;
111hp/114ft.lbs, TTS Mastertune
ProStreet Trike; Custom Eagle/Flames paint scheme 98ci; GMR Stg 3 Heads; Woods 6 Cams & Lifters; Smith Bro Rods; SE Comp & Clutch; Samsom HellRaiser Pipes; S&S Dual Intake; PM Heathan 21" Fr Wheel; Weisco's @10/1;
104hp/110 ft.lbs, TTS Mastertune
DocDyna is offline   Reply With Quote Quick reply to this message
Old 12-20-2009, 10:06 AM   #7 (permalink)
sporty952 wants to know Dino or Syn?
Get the ABS system installed... :-) Then the light will mean
something...
-W
sporty952 is offline   Reply With Quote Quick reply to this message
Old 12-22-2009, 05:37 AM   #8 (permalink)
cata5803's Avatar
ABS light on, Bike has no ABS installed.. Good Luck.. Could it be that you do have ABS and just don't know ?? Thought i'd ask, some times it's the simple fixes that blow me away. Have you taken it some where to be checked out ?? Just qurious..
Old 12-22-2009, 06:48 AM   #9 (permalink)
strokerjlk's Avatar
JUST A GUESS HERE!
I have found on the ABS bikes when I dyno them then the ABS light will have to be reset by going through the routine to reset all codes. 1/2 the time it doesn't throw a code. but when I go through the sequence to reset as if there was a code. it will reset the ABS light. I haven't ran into a 08 up ABS compatible bike without ABS to know if this would be the same,but worth a try.
I would ass u me that the wheel sensor is still active then even without the ABS option.
07 ULTRA
AMRA
SE 218
DR 218
Old 12-23-2009, 07:15 PM   #10 (permalink)
No wheel Sensor
I looked the front wheel over good and did not see any sensor or wire for it. So I went to dealership just to look at a bike with the sensor, in case I was just missing it. The ones at the dealer have a black ring on the inside of the fork next to the wheel hub. So I came home and did a good inspection, found nothing like the black ring on my bike. So I am sure it does not have it. I bought this bike used with 149 miles on it. Can't get ahold of the original owner, he moved up to the N E somewhere, not sure where. I thought that somewhere I could plug in the VIN and find out bike build data. I will try he reset even though there is not a code displayed.
Old 12-23-2009, 09:04 PM   #11 (permalink)
strokerjlk's Avatar
keep us posted.
this has got my curiosity up now.
07 ULTRA
AMRA
SE 218
DR 218
Old 12-23-2009, 10:08 PM   #12 (permalink)
hdmikeyb wants to know Dino or Syn?
Question
It's real easy to tell if you have ABS. Pull the right side cover and the ABS module is right there. It's a machined block of aluminum with several brake lines running to and from it. Also the brake system reverts back to a foundation brake system ( that is a brake system on a vehicle without ABS) anytime there is a failure in the ABS. (Federal law under NHTSA code). The ABS warning lamp illuminates when the bike is first started and stays on until the ABS module recieves the wheel speed sensor inputs from both wheels. If the warning lamp remains on there is a failure in the system. If it is a "hard" (constant) and (present) failure the light will not be able to be shut of until the failure is repaired.
hdmikeyb is offline   Reply With Quote Quick reply to this message
Old 12-23-2009, 10:13 PM   #13 (permalink)
strokerjlk's Avatar
Originally Posted by hdmikeyb View Post
It's real easy to tell if you have ABS. Pull the right side cover and the ABS module is right there. It's a machined block of aluminum with several brake lines running to and from it. Also the brake system reverts back to a foundation brake system ( that is a brake system on a vehicle without ABS) anytime there is a failure in the ABS. (Federal law under NTSB code). The ABS warning lamp illuminates when the bike is first started and stays on until the ABS module recieves the wheel speed sensor inputs from both wheels. If the warning lamp remains on there is a failure in the system. If it is a "hard" (constant) and (present) failure the light will not be able to be shut of until the failure is repaired.
he knows he dosent have ABS
He was looking to see if he has a wheel speed sensor.
07 ULTRA
AMRA
SE 218
DR 218
Old 12-28-2009, 06:51 AM   #14 (permalink)
cata5803's Avatar
Have you found the answer?? Just wondering if you found a problem,,
Old 01-02-2010, 06:28 AM   #15 (permalink)
No ABS
No Module under the cover
Thanks for help
